Paper Pro Prodigy stapler won't staple. When press down on top it won't activate. Feels like a spring inside is not activated.
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
Apr 02, 2015 | Office Equipment & Supplies
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
I have a bostitch stanley desk top stapler model # 02210, it will not activate the staple when you put the paper in it, does that little trigger in there have a spring on it because it will not return to...
The case of the stapler is glued together. To open the case requires carefully sawing it along the seams. The paper switch is spring loaded but the spring is built into the switch. It is possible that something is jamming it.
Nov 09, 2010 | Stanley Bostitch Bonus Pack Electric...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
There is a Stanley bostitch model B2000 stapler in my classroom. I need to fix the spring that advances the staples and holds them in place! wehre do connect the spring?
The person that asked this is probably long gone, but in case anyone else comes across this... I had the exact same problem when I dropped this same stapler today and the spring came out. After examining it for a bit, I realized where the spring had to go and fixed it.
Open the stapler the same way you would as if you were replacing the staples and look at the top piece, towards the back. There will be an elongated black hook here to attach one end of the spring. The trick is where you route the spring after that... look towards the front end of the same top piece, and you'll see 2 holes in the metal. You need to push the spring up through the first hole, then pull it back down through the second hole (you may want to use a straightened paper clip to snag the spring so you can pull it through that second one), and only then do you attach the other end of the spring to the hook in the sliding metal piece that advances the staples in the staple holder.
And that's it!
Feb 25, 2009 | Arrow 8000 Power Shot Pro Staple & Nail...
PaperPro 1110 Prodigy metal stapler Has ceased up. How do you open the top to access the mechanism? thanks Gerard
My PaperPro Prodigy stopped firing staples. Examination of the hammer mechanism was fine. (apparently sometimes an internal part can break) Check with stapler opened and no staples. Hold the safety lock pin down with a fingernail or sticky tape so you can check operation of the hammer mechanism. Should withdraw to clear staple compartment and then fire. If this looks good, examine the roof of the staple compartment. Mine had a little lump of brown grunge in the roof of the staple compartment next to the hammer - stopping the staples from sliding up into firing line. Scraped it out and works fine again.
Apr 02, 2008 | Cell Phones
2,983 people viewed this question
jasbo
jasbo
