Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
My fisher/paykel dishwasher does not complete a cycle. it begins to wash and then acts like it in pause mode
  • Fisher and P... Master
  • 3,247 Answers
It is possible the delayed start option has been set by mistake.
The way to cancel that would be to press the power button off and then on.
However, I am assuming this problem is with only one of the two drawers.
But I am not sure how much of the wash cycle is done before it goes to pause, eg. do you hear the water flowing in, do you hear the washer arm moving and throwing water around?
If it does not get to the stage of water coming in but you do hear some sounds as soon as the start button is pressed then it is likely the door seal is not setting properly which causes the dishwasher to stop.
Anything you see on the display or lights (if no LCD display)? Trying cleaning the door seal with a clean damp cloth. If problem still there then you need to get the door seal serviced. It is slightly sophisticated part with seal and two motors which require some expertise to replace.
Happy to guide you if door seal replacement is needed. Post me a comment on what you find.
Posted on Jul 14, 2010
How do you control dd605i dishwasher when touch controls do not work? My wife saw the service man control the top panel using the front buttons.
This will only control the diagnostic service mode, it will not run a regular wash cycle.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 09, 2014 | Fisher and Paykel Dishwashers
Fisher paykel dishdrawer lid will not stay locked
Assuming this is happens with only one drawer - most likely controller is recongising some sensor problems. If the water inlet is faulty then it is waiting for water to get in. Alternatively, the sensor that tells it the drawer is closed suddenly misbehaves and confuses the controller which stops the cycle.
Feb 13, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a fisher pakel double drawer dishwasher and it keeps pausing a couple of times through the cycle how do I stop this
Pausing - how long? The pause means the wash motor keeps halting as it is waiting for the water temperature to increase to the right wash selection. If the heater is sluggish then it will take longer to heat. Try a simple rinse cycle and see if there is any difference. (Rinse cycle will use cold water to complete)
Dec 04, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Purple light is on and cycle won't start
It's possible that you have put the dishwasher into delay mode. Try powering off at the powerpoint as this will force a reset of all programming.
The pause/start button also sets the Delay Start feature which can delay the start of a wash program
from 1 to 12 hours.
To cancel Delay Start
Press the I button.
Dec 30, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishwasher noisy fan
Have you got your dishwasher on an extended drying cycle?
Normally it works for about 10 minutes after the wash cycle is complete - not hours.
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Sep 08, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and Paykel Double dishdrawer - U3 error. Stops washing about 5 minutes into the cycle.
when you start the unit let it run for a minute then pause it before it starts to fill and check to see if it's drained it's water if not then you have a drain fault cheers. fell free to Chat live if you want me to talk you through it cheers
Aug 11, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
224 people viewed this question
Top Fisher and Paykel Dishwashers Experts
TomDicker
Level 1 Expert
Simon Flummox
Simon Flummox
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
