Question about Maytag Neptune MDG5500AW Gas Dryer
My Neptune dryer is not heating all the time it's running but stops heating after awhile
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
My maytag neptune gas dryer runs, starts to heat, but then the heat stops
www.repairclinic.com is where I go for information and parts. I am a do it yourselfer and only work on my stuff. Hope this helps. Sounds like the thermostat is getting week. Or the overheating cutout. Hope this helps.
Oct 06, 2014 | Dryers
Our dryer heats for awhile, then shuts off. If we let it cool down,it will turn back on for awhile., then get hot, then turn off again
Check to make sure vent/air flow is not restricted.
Try to start dryer soon after it stops. If it hums and does not start, motor is cutting out.
If you touch the motor you will find it to be 'very hot' Touch only for 3-4 seconds.
Oct 18, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Our Maytag Neptune gas dryer is exhausting a natural gas odor now... This smell only occurs when it has been running for awhile and never when it's turned off. Also, it ONLY smells outside the house via...
The burner is not lighting right...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune mdg3000aww starts heating and runs fine but stops heating shortly after start up can restart heater starts again and shuts down
If the machine keeps running but just not heating you have a thermostat issue. It could be the operating therm. or the high temp limit therm malfunctioning, shutting off the element.
If the machine stops running completely, check the door switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
382 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
