Question about Porter Cable C2002 150 Psi 6 Gal Compressor
My porter cable c2002 150 psi gal compressor the pressure regulator is always set at 0 and no air at outlets, but the tank is fill of air 150psi. what could be the problem
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Posted on Dec 20, 2010
    New Friend:
    Problem Solver:
  • 8 Answers
Inside the knob is a a spring, and a black plastic plunger thing. The plunger is broken. I have the same problem. Aside from ordering a kit or a new regulator/manifold. eBay is the only way to find the one piece you need. If you find anything out let me know. Oh and plunger is not the name.
Posted on Apr 13, 2013
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
Tank isn't filling up
Make sure your hose doesn't have any leaks. Also, check the check valve for dirt or wear. Your pressure regulator could also be stuck in the blow off position.
Feb 02, 2012 | Porter Cable C2002 150 Psi 6 Gal...
My compressor tank fills like it should and sounds normal but none of the tools are working. this happen to anyone else?
Have you adjusted the pressure regulator knob for air flow? If so, the regulator may be plugged. Clockwise increases line pressure.
Jan 22, 2012 | Porter Cable C2002 150 Psi 6 Gal...
My psi is 150 and the tank turns off but my regulator pressure is at 0, this is a brand new tank and never been used before.
Hi scooterb88...
Sounds like your pressure regulator needs adjustment...
Turn the knob on the pressure regulator clockwise and you should start hearing air coming out of your hose...Once air is coming out, remove your hose and keep turning the regulator till you get to your desired working pressure normally around 90 psi...leave your pressure regulator at that setting and it will stay at that setting.
Please take time to rate me
Sep 17, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Porter cable the compressor regulator is always at 0, the tank is at 150psi but no air at the outlets
Always at zero,like the regulator is broken?
I would assume that you never set it to whatever
pressure you want to use
Jul 31, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have the 2002 comprssor , the outlet pressure gauge does not register when the tank is filling or full, tank will not operate.
It is possible that your air pressure guage is faulty and needs a replacement. Make sure the air control regulator tap is working fine or else replace the tap if cleaning wont help.
Bothe the tap and the air pressure guage are available easily and could be replaced by you.Use the correct wrench and use teflon tape to the screw thread, do not over tighten.I hope you try.Good day
Aug 15, 2010 | Porter Cable C2002 150 Psi 6 Gal...
No air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Nov 06, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
1,459 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
