Question about One For All URC-5705 Remote Control
Using urc3030b01 oneforall remote need code for philips t.v.
ziraffa
  • 827 Answers
SOURCE: need codes for programming a philips TV
http://www.urc.philips.com/
you have to input if you're european or american, into the box on the left.
i found these codes:
PHILIPS ............ 807 022 020 422 122
.................... 222 322 002 430 901 402
.................... 408 109 210 310 715 520
Here's a link to download the urc user manual too.
http://safemanuals.com/user-guide-instructions-owner-manual/ONE%20FOR%20ALL/URC%203021-_E
good luck
chris
Posted on Dec 17, 2008
SOURCE: need the codes for a
http://www.xdiv.com/remotes/
Posted on Jan 02, 2009
  • 30 Answers
SOURCE: oneforall URC-3220 universal remote
Try this:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=oneforall
Posted on Sep 13, 2009
  • 102 Answers
SOURCE: oneforall remote control - Proline freeview box
Hi here are the codes for Proline> 0651 0686 0672 0790
1004 0652 1483 0833 1738
if you have any problems here is a link to the manual>
http://www.oneforall.com/uploads/support/0bd2c0caaa502fc6d6ce79c022e8128a.pdf
Posted on Feb 03, 2010
Wins411
  • 166 Answers
SOURCE: i need codes for the oneforall remote for a sharp tv
You can download the PDF of the manual here:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3021
But as for your question Sharp TV codes are:
0093
Only one listed in manual.
Posted on Apr 30, 2010
I have a oneforall remote urc 4081b00. I need the codes for a Philips DVDR600VR/37 DVD Recorder VCR Recorder.
Codes, if applicable, are in the remote. Use code search to find what you need but bear in mind that only some functions may be controllable. If a search through all codes contained in the remote fails, you may have to try a different universal remote, e.g., Philips.
Jul 27, 2016 | Philips Televison & Video
I need codes for a philips tv Pl7125 for my oneforall universal remote
Go into Google and type in Phillips TV Codes. There is a complete list. Sorry, but the link is too lengthy to post here. Best Wishes
Sep 02, 2014 | Universal Remote Control Televison & Video
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
Need code for philipimagnovax tv got oneforall remote big easy
The manual (and code list) for the URC-4330 Big Easy remote is available here: http://www.oneforall.com/uploads/support/c075467748de47c728c408ada35fd3c1.pdf .
For a Philips Magnavox TV, try 0054, 1254, 0030, 0179, 0187, 0096, 0020, 0186, 0386, 0024.
Please note that the codes in a universal remote are generally limited to those for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a newer remote. The URC-4330 documentation dates from 2001.
I hope this helps.
Jul 04, 2011 | One For All URC-4330 Remote Control
Need code for Philips tv. to program oneforall remote control..
Hello
Setup codes for Philips TV with One For All URC-3021 remote control are:
0054, 1454, 0690
OK.
Jun 09, 2011 | One For All URC-3021 Remote Control
I'm trying to program my remote to my Philips tv
Site for the remote:
http://www.oneforall-na.com/remote.php?type=URC%203021
Site for the codes:
http://www.oneforall-na.com/list_codes.php?db_value=expert4&remote_choice=URC%203021
Codes for philips tv:
0305 0317
May 04, 2011 | One For All URC-3021 Remote Control
Tv magnavox one for all remote need codes
Go to www.oneforall.com and enter your oneforall remote model number. It should show a list of all the codes for your remote. Thanks for using fixya.
Dec 01, 2009 | Philips Magnavox 20MS3442 20" TV
I have lost the code for my remote. It is a oneforall brand remote and the TV is magnavox
What model # is the oneforall remote would help. Here are some codes to try....some remotes use 3,4 or 5 digits. TV
Philips
0054, 0030
TV
Magnavox
0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171
MAGNAVOX
11423, 12311, 13433, 11221, 11231, 11241, 11243,
13434, 11232, 12123, 11321, 11132, 11134, 11142,11414,11144, 12122
PHILIPS
11111, 11423, 11232, 11144, 12122,11314, 12212, 11443, 11232
Magnavox 1223, 1311, 1423, 1424, 1142, 0020, 0024,1124, 1243, 1133, 1321, 0000, 0035, 0039,0081, 0110, 0149,0230, 0386
0028, 0030, 0036, 0054, 0096, 0186, 0187,0230, 0386
Philips 1223, 1311, 1132, 0054,0028, 0030, 0036, 0054, 0096, 0186, 0187,
0230, 0386 1124, 1243, 0035, 0062, 0081, 0110,0028, 0030, 0036, 0054, 0096, 0186, 0187,
0230, 0386
PHILIPS
029
MAGNAVOX
083,029
Some may be repeats but, I just cut and past from my manual I am editing.
Nov 23, 2009 | Philips Magnavox 20MT133S 20" TV
Code for philips CL035A
Look for your code at
May 08, 2009 | Philips Magnavox Learning Universal Remote
One For All URC-5705 Remote Control Logo
100 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
