Question about Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Posted on Jun 16, 2012
  • 4 Answers
E4 or E-4 error message in the Wolfgang Puck Pressure Cooker usually means that the pressure cooker is not building up pressure, meaning it is not sealing properly.
This is frequently caused by the pressure relief valve not properly seating. Usually you can get the relief valve to seat by putting a little pressure on the top of the valve and wiggling it around. This will rub off the layer of minerals that have built up on both the valve seat and the valve needle. If that doesn't work, pull the top of the valve out of the seat, and manually scrape off the buildup of the mineral buildup.
Not properly sealing can also be caused by a mis-alignment of the pressure cooker gasket seal. It sits in the lid part of the cooker. It can become a bit stretched. First note the location of the gaske, then take the gasket out and gently clean it. Put the gasket back in the lid and carefully put the lid back onto the pressure cooker. You can tell that it is properly seated if there is no gap between the lid and the pot. If there is a gap then the gasket is misaligned and so the lid is not seating properly.
Once you get the pressure release valve, and the gasket seal properly seated, unplug the pressure cooker to clear the E4 error message and try using the cooker again. Make sure there is liquid in the pot so that there will be steam to cause pressure.
Once the timer clock starts ticking down, there should be very little steam coming out of the cooker. Your pressure cooker should work fine now.
If not, you can try the methods described in other answers.
Posted on Mar 14, 2015
Omg..Eric..you were right on the money with your instructions...I had my pressure cooker for probably close to 3 yes or more and this was the first time the e4 code came out..I did other people recommended and nothing...I follow your instructions and bingo...I'm am cooking my chick peas right now...thanks a million...I was bummed out thought I had to go to buy another one and I surely am tight in money...thanks again!
Posted on Jan 23, 2015
I have been helped by the solutions suggested above, just got to contribute something.
I got this E4 code today, the pot is cool, there is no water inside, don't know what to do with it.
inspired by the solution above, I opened the bottom lid, make sure you unplug the power cord. Only three screws, very easy to open.
You will see one metal switch at the edge, and two blue wires connected with that metal switch. Just press the white button of that switch a few times you should hear little click sound and feel the switch been pressed down.
After that I just put the bottom lid back and plug in power cord. And start cook, it works fine.
I notice that there is some old cooking stuff already dried on that switch, that means sometime back I must have some spill over which got liquid entered into the bottom compartment. I cleaned that as well.
Posted on Jan 21, 2014
    Problem Solver:
  • 18 Answers
SB37438 has a good idea there.
I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this.
The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook.
Pics of process:
http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Posted on Dec 03, 2013
I need instruction on how to operate and set up
Posted on Jul 11, 2010
Need his pressure cooker chicken & dumpling recip
wolfgang has a web site, ,did you try to Google it? I did and it came right up.
May 06, 2015 | Wolfgang Puck 5-Quart Electronic Pressure...
I NEED TO REPLACE THE PRESSUR RELEASE VALVE. WOLFGANG PUCK 5 QT PRESSURE COOKER MODEL BPCR0005.
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
If you do not see the part you require suggest you contact their Customer Service at 1-800-275-8273 or make an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Dec 06, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Seeking owner manual for Wolfgang Puck Pressure Cooker BPCR0007 online. Does anyone know where I can locate a copy?
Wolfgang Puck Instruction Manual for the BPCR0007 is available here:
http://www.wpcookware.com/manuals.asp
Sorry someone has not got back to you sooner but I just discovered this site.
Oct 30, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Where can I find a cord and valve for my wolfgang puck pressure cooker 7 qt.? Lost during a move
Replacement parts for the Wolfgang Puck pressure cookers are available here:
If you do not see the parts you require or are unsure about the model number; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
Sorry someone has not responded sooner.
Oct 26, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Manual Wolfgang Puck #BPCR0005
Here is the site for this pressure cooker and model # that you need...
It's on the left hand side under the panini maker...the picture is of the 7.5 size but under that picture it does have a drop down menu that says model # and that 5 qt Pressure Cooker with that Model # is there...
Good Luck
Shelly
Oct 12, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Can't get sealing gasket to seat properly
Didn't find a solution - not interested in paying for a solution. Product sent back.
Mar 22, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Instruction handbook
Hi
I think you need to call thier help line
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
Feb 16, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Wolfgang Puck Bistro 5 qt Pressure Cooker. How to steam?
Throw away this "Made in China" piece of **** and buy American. That's what I had to do.
Jan 05, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
Wolfgang Puck 5-Quart Electronic Pressure Cooker - Silver Logo
1,522 people viewed this question
Top Wolfgang Puck Crock Pots & Slow Cookers Experts
Sloop Johnb
Are you a Wolfgang Puck Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
