Question about Sony CDP-CX350 300-Disc CD Changer
My Sony disc player cx-355 displays a "Loading Error" message and will not play discs. How can this be fixed?
  • rwvetter Jul 10, 2010
    I need some more information. See my follow upe-mail.
  • Sony Master
  • 6,993 Answers
was this player loading discs before and how long have you been using the player. I suspect that the lens of your player is weak, that's why its not loading disc.
Its either the lens is very dirty, or the laser (lens) is weak.
Get a cotton board, open the player's cover with a screw driver in order to gain access to the lens, and use the cotton board to clean the lens thoroughly. After the cleaning try again.
If the player still does not load after you have cleaned the lens, then it mean the lens is weak such that it cannot be revived. In this case you will have to replace the lens completely to a new lens.
Go to any electronics accessories store within your vicinity, and get a new lens. You can remove the old lens and use it as a sample to get the new one.
Good luck.
Posted on Jul 10, 2010
  • 1 more comment
    Do I use anything but cotton such as alcohol or eye glass cleaner to clean the lens? If I have to replace lens, would Micro-Center or similar store have a replacement laser lens? If not, who would?
    The unit was working fine a month ago. It is not used often. I had no prior problem until about a week ago. Do I use any alcohol or glasses cleaner to clean the lens. Would Micro-center carry a replacement laser lens? If not, who would?
  • Walesarumi
    Walesarumi Jul 10, 2010
    Hello.
    you can use alcohol or glass cleaner to the lens. Make sure you dry off the alcohol from the lens. Since you don't often use the player, then, cleaning the lens alone might solve the problem.
    Try Micro-center, and if they don't have it, you can ask from them as they should be able to direct you to a place where you can get it.
    We don't stay in the same vicinity, so I would know a precise place where you can get it in your area.
    Take care.
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
Sony cdp cx 355 displaying table error
What worked for me was taking the cover off and carefully threading a belt back onto a wheel. There are two motors at the back of the unit, one (I believe) that grabs the discs and moves them in & out of the player, and a second one that rotates the table (i.e., the round slotted thing that holds all the discs). The belt had simply slipped off the wheel that drives the latter. I did remove the back panel as well, to access it better, and inadvertently disconnected a sensor plug, which led to a second round of troubleshooting, but - in the end - I got it working!
Feb 03, 2010 | Sony CDP-CX300 CD Player
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Sony DVD RECORDER/PLAY WON'T PLAY
Dvd players are only made to last a couple of years(the laser goes bad).If you play scratched disc's it won't last that long.Hopefully you didn't pay alot for the player,and if you did then you can get the laser repaired but its expensive.I usually wait until the things go on sale and pick one up for 20 or 30 dollars.When the laser burns out after repeated use I just buy a new one because fixing them is more expensive and unless you want to continue having problems its easier to buy new.These guys that put alot of money in these units are just wasting their money.
Jan 18, 2009 | Sony RDR-GX300 DVD Recorder
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Dec 28, 2007 | Sony SLV-D350P DVD Player/VCR
Sony CDP-CX350 300-Disc CD Changer Logo
267 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
