Question about Mr. Coffee 12-Cup Programmable Coffeemaker
Water is not running through the machine.
I have the machine ready to go with coffee and water and it's plugged in. When I push the button to start brewing it turns green but nothing happens.
  • rkaplan479 Jul 10, 2010
    As I think about it the water must not be heating. What would cause that?
    I don't know yet
  • 2,272 Answers
  1. Make sure the coffeemaker is plugged into a working 120V electrical outlet.
  2. Make sure the power switch is turned on.
  3. Make sure the water reservoir has water in it.
  4. The unit may require cleaning to remove mineral deposits that build up over time.
  5. If the coffeemaker is equipped with a clock and the clock is working properly but the unit will not brew, please contact the nearest Authorized Service Center.
  6. The unit may require cleaning to remove mineral deposits that build up over time.
  7. Make sure the filter is properly in position and that the brew basket is fully closed.
  8. If the coffeemaker is equipped with a removable water reservoir ensure that the reservoir is properly installed.
  9. Avoid overfilling the water reservoir. The coffeemaker is equipped with an overflow slot near the top of the water reservoir. If too much water is added it will flow out of this slot and collect near the base of the unit and brewing will not start.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 10, 2010
  • raj somaiya
    raj somaiya Jul 10, 2010
    There is a warming plate in the unit to make the water warm and to brew the coffee to drip it warm in the cup.
    If coffee brews cold,or coffee does not warm the water to start brewing the warming plate is not getting warm, your unit may need to be repaired. The warming plate needs to be checked.Either the plate needs replacement or the wires which connects the plate have got cut in between or short.
    Thanks for updating with your query.
    President:
  • 1,561 Answers
There two possible reasons for this problem, you will need to check this two options to fix the problem.
  • The one-way valve can get clogged open or closed. You can usually fish out the debris that causes this problem with a toothpick.
  • The tubes can get clogged with calcium. This is especially true of the aluminum heating tube. The normal way to solve this problem is to run vinegar through the machine once, and then run two batches of water through to clean out the vinegar.
Take care.
  • Sulaimon Jimoh Olayemi Jul 10, 2010
    The problem of water not heating is cause by the heating element. The resistive heating element is simply a coiled wire,
    very similar to the filament of a light bulb
    or the element in an electric toaster
    that gets hot when you run electricity through it. In a resistive
    element like this, the coil is embedded in a plaster to
    make it more rugged. The heating element has two jobs:
    • When you first put the water in the coffee maker, the heating
      element heats it.
    • Once the coffee is made, the heating element keeps the coffee
      warm.
    The heating element might be defective, since you the water is not getting hot.
    Take care.
How do i open water resovor on krups oblo coffee maker
See page 8
8
8
FIRST USE
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
ON
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
seconds.
8
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
Bosch Tassimo TAS4513UC 1-Cup Coffee Maker manual
I looked up your problem and found the same one was answered previously on fixya. I have copied and pasted the previous answer here for you. Good luck and I hope you have a great day!
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Mar 25, 2014 | Bosch Tassimo TAS4513UC 1-Cup Coffee Maker
When I turn on the coffee machine flashing red button calcing. and 'put in a container for water descaling solution., when I hold the button for more than 5 seconds nothing happens.
push it for 5 second and if its still flashing doesn't matter turn the steam knob anti-clockwise end let the machine do to the descaling cyrcle, when then water tank emptied the rest of buttons starts to flashing, turn the knob off and your machine is ready!!
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
Will not start descaling
2. Mix in descaler.
Found the answer on another fixya post. Seems like about the same product.
http://www.fixya.com/support/t6123164-tassimo_red_light_stays
Apr 17, 2013 | Coffee Makers & Espresso Machines
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
How do you descale a Saeco Magic Comfort Plus coffee machine? do you buy some fluid from somewhere and pump it through or what?
Hi
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process and when it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to "reset descale", push the enter button and chose "Yes" and push the enter button. Now it will tell you we next to be descaled.
Jun 11, 2010 | Saeco Magic Comfort Plus Espresso Machine
We dont have a manual for our Saeco Magic comfort coffee machine and the declcify message is up on the screen. What do we do?
Hi
Enter the menu by pressing the menu button. Scroll down until you reach “water hardness” and then press the menu button to activate. Scroll down to the hardness of your water (chose 4 to be safe) and press the menu button again for the computer to remember. Push escape (esc.) and scroll to “Descale) about 4 up from water hardness, and push enter.
To descale your Magic Comfort +, enter the menu and scroll to descale. Push the menu button to descale. Mix your solution in your water tank. Use warm to hot water and dissolve all the solution. Place the water tank on your machine. With a container under the steam wand that is large enough to catch all the water in the tank, you are ready to begin. To start the descaling process, open the steam knob. The machine will automatically start the descaling process andwhen it is finished, it will shut off and tell you that it needs to be rinsed. Remove the water tank and rinse with fresh water. Refill the water tank and place it on the machine. Turn off the machine, wait a moment, and then turn it back on. Press the hot water button to start pumping fresh water through the boiler. Pump out about 16 oz. of water and then turn off the hot water button and open the steam knob to rinse the steam boiler. When it starts to go to steam, turn off and turn on the hot water button again. Pump out another 16 oz. Repeat this process with the steam knob until you have emptied the water tank. Descaling is complete. Go to your menu and scroll to “reset descale”, push the enter button and chose “Yes” and push the enter button. Now it will tell you we next to be descaled.
Apr 20, 2010 | Saeco Magic Comfort 103467 Espresso...
Cuisinart coffeemaker won't brew
A common problem that can occur with the Cuisinart coffee maker is it will stop brewing, even when there is water ready to be transformed into coffee. The machine still turns on and works like it should, but does not continue brewing an entire pot of coffee, and acts like it has finished brewing even when there is still water sitting in the bin. This type of problem is pretty common among various coffee makers, and usually occurs when there is a problem inside the machine.
One of the best ways to fix this problem is by flushing the coffee maker out with a vinegar solution, which can be made with equal parts of vinegar and water. It should be poured in the same place as the water that is ready to be brewed, and will help to clear out the machine and make it ready to start brewing again. This problem is usually caused by calcium building up within the machine, and the vinegar helps to clear out any blockage to help it start running smoothly again.
Nov 01, 2017 | Cuisinart Coffee Makers & Espresso...
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Mr. Coffee 12-Cup Programmable Coffeemaker Logo
88 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
