Question about Maytag MVWB300W Top Load Washer
My washer is shaking during rinse cycle, HELP?
Maytag centennial washer, during the spin cycle, the machine is shaking uncontrollable and making noises. I had to stop the rinse because it sounded like the drum was about to pop out. How do I fix this?
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
Maytag centennial washer won't fill during rinse cycle
If the inlet works during the wash cycle or start program but does not work during the rinse cycle, then it is due to fault in the program. Select another program to confirm this cycle or choose another cycle. If the fault is the same on all the programs then it can be due to the controller unit.
May 04, 2015 | Maytag Washing Machines
Recently, my Maytag Centennial washer is incredibly loud even with very small loads. This happens during the spin cycle. It almost sounds like a truck
Need new shaft bearing. Seals kit .
I've repaired lots of these. Bearing tool is required. Part W10435302 tool W10447783
Tilt washer back look around the motor. Big piece under tub. If you see mud or rust leaking out of motor you should replace this soon.
Dec 07, 2014 | Maytag Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
Maytag MVWB300W Top Load Washer Logo
280 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
