Question about Frigidaire Electric Dryer
My dryer only hums when I turn it on
My dreyer only hums like its trying to come on, but it doesn't. I've unplugged it, plugged it back in, doing whatever I can do to reset it. It did this once before some time ago.
    President:
  • 1,554 Answers
This is an obvious sign of a motor problem if the humming noise is coming from the motor itself. Otherwise, if the humming noise is coming from the timer, then most likely you have a blown thermal fuse which is usually wired in series with the motor circuit. Failure of the thermal fuse results in the dryer not running because it terminates power to the motor.
Please indicate the exact model number of the dryer for a more specific and accurate troubleshooting and repair advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from doing so. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 10, 2010
How do I get into the dryer to replace the drum belt?
May I suggest you type "SearsPartsDirect" into your computer search engine, and then type in the model number found on the tag somewhere on the machine.
If they list it, you should find pictures of the machine.
To get to the dryer drive belt, you have to take the whole machine apart.
God bless your efforts.
Oct 03, 2017 | Equator ED 620/W 110V Dryer - White
Dryer sometimes works and sometimes doesn't, what's the problem?
i have a feeling that it's a fault in the power chord, take it out and double check. it would make sense if it only work now and then after you have plugged it back in because it could have made the wires touch again to make it work
Jun 29, 2014 | Whirlpool Washing Machines
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
My LG Tronn Dryer will not turn. The Check Filter light was on and we cleaned the filters and it went off. The dryer hums when the power is on but does not come on or the drum does not move. The drum
listen carefully to the hum if it sounds like the motor is running its a broken belt, if it sounds like its not turning it could be the capacitor on the motor.
Dec 17, 2012 | LG Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 30, 2012 | Kenmore Dryers
Makes a humming noise but doesn't turn
Try this, open the dryer door and hold down the door light switch. Turn on the dryer and press start.When you hear the motor humming, turn the drum clockwise with your hand to see if it will turn. If itruns, you have a bad motor and will need to be replaced. If it doesn't turn, something is jammedinside and you will need to disassemble the unit to find the jam.
Hope this helps.
Oct 31, 2011 | LG DLE2514 Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My whirlpool dreyer does not work. power turns on
It has a bad Thermister. you will need to chage it. it is right on top of the blower housing
Jan 20, 2010 | Whirlpool GEW9250 Electric Dryer
LG DRYER DLE2516W
The timer is not advancing itself to the OFF or open cam, which opens points and stops the timer motor.
You will have to replace the timer to correct the issue.
Dave E. (Illeagle)
May 30, 2008 | Dryers
Frigidaire  Electric Dryer Logo
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
