Question about Invacare Supply Group Health & Beauty
Heavy steering on my s/h sungift 200,ok when raised off ground.tyre pressures correct.could it be something to do with the fibre washers on the main steering column.i dont think it is very old.have checked all other joints seems to be ok,but steering is very stiff,very puzzled.have any similar owners had same problem? dave
  • 177 Answers
Hi Dave. I have had a few scooters that have had this problem. Most of them had the bearings tightened up to tight. Either the bearings on the steering column, or the bearings in the left or right stub axles. Just loosen off very slightly will help. Make sure that there is not too much movement in the bearings after adjusting them. Also give all the linkages a bit of a lube.
We are Invacare sales and service agents here in New Zealand, but I have never heard of this model.
Good luck. Neil.
Posted on Jul 13, 2010
The steering on my 2006 Cruze has become very heavy at low speeds. Any ideas on what to look for?
check tyre pressures first if correct about 2.2 bar ,then change the load/pressure switch on the steering rack ,it should be located where the drive goes into the steering rack ,unless you have a electric motor system and not hydraulic if this is the case then dealer only as the control unit is all electronic and has to be centralised ,if some unskilled know it all has adjusted tracking but only on one arm then steering wheel spokes will be out of position and this will cause big problems .
Dec 17, 2016 | Cars & Trucks
What is the correct tyre pressure for a 205/50/16
depending on the vehicle /weight and expected speed, 26-28 psi. heavy vehicle or travelling at high speed it can go up to 30psi. The recommended tyre pressure will be on the specification plate for wheels and tyres on the door edge or door opening pillar. Some makes of tyres have the tyre pressure moulded into the side wall of the tyre.
Aug 30, 2014 | 1998 Ford Laser
Is it ok to put spacers on my 1998 grand Marquis to fit my twenty two in rims how much do i have to raise it and wat could happen if i continue driving without raising
Spacers behind the rims are definitely illegal as the stud length will be too short and too small for the extra load. IF you don't raise it then I think that the wheels will hit on the guard edges and get cut to pieces . You will have to raise it so that the maximum deflection of the suspension ( distance between the suspension bump stop and the chassis ) is greater than the distance between the top of the tyre and the guard edge by at least 1/2 inch. The profile of the tyres will be very small say 250.25/22 and that will be minimum side wall between the rim and the ground . Remember that you have to retain the same overall diameter of the tyre as was originally specified for the vehicle or you will be put of the road and face a heavy fine all for no advantage other than to say it looks good.
Mar 16, 2014 | Cars & Trucks
Correct tyre pressure
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
Tire pressure check and adding air
How to check your tire pressure
Bajaj Avenger 2006 service manual DOWNLOAD FREE FULLMANUALS COM
http://www.marutibajaj.com/pdf/Avg-200.pdf
Bajaj Auto Avenger 200 User Manual
Feb 14, 2014 | Bajaj Motorcycles
Hello My 1996 discoverys steering is very very stiff especially when turning right. This problem dissappears soon after the vehicle starts to move. The problem started two days ago. steering fluid level...
hi.
if the fluid level is ok, then there is probably not a leak in the system.
check the tyre pressures are correct as underinflated tyres can make the steering heavy, as well as increasing tyre wear.
if the tyre pressures and fluid levels are ok then check the belt driving the power steering pump is ok.
other problems include a bad power steering pump. a faulty rack, or siezed joints on the struts.
Feb 25, 2011 | 1998 Land Rover Discovery
I have a sungift 200 mobility scooter with an intermittent power problem. I have removed the top cover of the steering column, and there is no immediately obvious fault i.e corroded or disconnected wires....
there is a short in the cord going from the controller to the speed controller check the wire down through the tiller where it passes through the under the scooter i would bet on the wires being frayed and grounding out when you turn , patch or replace the wire and put wire loom over it to keep it from happening again
Jul 07, 2010 | Health & Beauty
I have a sterling 4 mobility scooter... steering is stiff and jerky...just put new tyres on... help please.....
I would think this will be head bearings. These bearings usually loosen rather than tighten up but if they do tighten up the steering will indeed become stiff and probably jerky if the cups that the ball bearings roll in have become a bit notchy. Its an easy fix and should just need loosening off. The bearings are located where the steering tube on the tiller passes through the frame. Its the large nut on the top that needs loosening slightly. There is usually a locking ring that may need lossening aswell. Please be warned that access can sometimes be an issue when trying to get at the headset. If loosening the headset does not cure this problem, there are normally a couple of sealed bearings located within the axle housing (the part where the wheel attaches onto). Its unlikely though that these will be causing your problem. If they are, they will need replacing which requires part of the steering assembly to be dismanted and for safety reasons, may be better left to a dealer. You menion about having new tyres. Was the steering ok before you had these fitted or were they fitted to try and cure this problem? If its the former, it could simply be incorrect tyre type or pressure. Before attempting to correct this problem, its probably a good idea just to lift the front of the scooter off the ground and turn the steering to be sure that the bearings are at fault and not the tyres. I hope I have been some help to you.
Mar 22, 2010 | Electric Mobility Mobility Electric Power...
I borgth 2002 kia rio, it has everything manual. the stearing is so hard to turn. what doI do ?
Run the air pressure in the front tires at 40 lbs pressure.
This may make it easier to steer.
This will cause the tires to wear a little faster in the center.
Have the front end steering and suspension components checked for binding or seized parts.
Sep 16, 2009 | 2002 Kia Rio
Open Questions:
Health & Beauty Logo
215 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
