Question about Lexmark X4650 InkJet Printer
Won't print, even when USB cable is plugged in
The printer is on and the USB cable is plugged in to my laptop but every time I try to print something a message pops up saying no print connection can be established.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 53 Answers
Do a BIOS update and than do a fresh installation of the printer.
Posted on Jul 10, 2010
Hi i have a Canon MP830 and have replaced all the ink cartridgers and they all light up but my printer wont print,fax,copy.It sounds like it is printing but the pagers come out blank.It won't even send...
Some laptops cannot run some printers or scanners. Make sure your laptop can handle running the printer from a usb port. It might help to have your laptop plugged into AC power. Also, make sure you have the most current printer drivers for your particular OS installed. If your laptop can't run your printer from its usb port, you can probably connect the printer to a desktop usb or a printer port, then print from your laptop through a home network.
Jul 26, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Just got a HP laptop for work that's running windows 7. It won't find our HP 5610 printer at home even tho I've downloaded the right driver
Is the printer directly connected to the laptop by a USB cable? Try a new cable. Check that the USB ports work by plugging in a known working device.
If you are using a print server or USB hub, try a direct connection. (If networked, check that your firewall isn't blocking the access by disabling it. If the print server is another computer, make sure that computer's firewall isn't blocking the laptop (trust level between the two machines).
I hope this helps.
Jun 28, 2010 | HP Officejet 5610 All-In-One InkJet...
PRINTER WILL PRINT COPY OF SOMETHING BUT WANT PRINT SOMETHING OFF COMPUTER.
This problem sounds like the printer is not set up properly on the computer. Have you installed the software that came with it? If so, look for the printer under control panel and then try a test page. If the test page doesnt work, how is the printer connected to the computer, by USB cable? If it is connected by usb, try shutting the computer down, unplugging the usb cable, restarting the computer and once it is fully started, plug the usb cable for the printer back in. Do you hear a tone after the printer is plugged in? If so try to print again.
Aug 11, 2009 | Office Equipment & Supplies
Problem with the USB port
Don't worry about the toner -it's gonna be more costly to replace your PC if you keep using this printer. i don't know the cause , but obviously if it has happened on multiple computers, there is some sort of short or something going on. Besides, a new printer these days (get your self an HP) is only about the price of a toner cartridge anyway - $100 +/-
Mar 25, 2009 | Brother HL 2140 Laser Printer
HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Jan 07, 2009 | HP Photosmart 8050 InkJet Printer
Printer wont print!!
Has it printed correctly before?
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 03, 2009 | Brother Multi-Function Center MFC-240C...
Failed to Print Error
Set powermode "allways on" for the lap top. Use an Usb cable no longer then 2 m. Try upgrade firmware for the printer. If still got problem use a powered usb hub between laptop and printer.
Nov 20, 2008 | HP Color LaserJet 2600n Printer
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
My hp psc 1210 won't work with vista
I had a similar problem! Here is what eventually worked for me, after searching through postings for hours on end...
First, I made sure I had the new driver. Second, (and this might be different for you), my computer recognized my printer, but any time I sent something to print, it never made its way there. The little printer icon at the bottom said 1 document pending, then quickly said 0 documents pending, but nothing ever printed. When I ran HP diagnostics, it said everything was okay with the printer, and even printed a test page! But still nothing from any other program. So, eventually I went to control panel, then printers, then I clicked on the HP printer, then right clicked and went to properties. I changed two things in here, and I'm not sure which one was the solution. First, I changed the security settings (in the security tab) so that every user had access to all options for the printer. Second, on the advanced tab, I selected print directly to printer instead of the spool print documents option. And tada it worked!
May not solve anyone elses problem, but I didn't see this solution in any of the posting sites, so I thought I'd share it. Give it a try!
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
Lexmark X4650 InkJet Printer Logo
195 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
