Question about HP Computers & Internet
Cannot uninstall cyberlink software from my computer the software is from the media now burning suite for dvd/cd burning. it is screwing up vista 64bit on my hp desk top
    President:
  • 2,571 Answers
You can try CC cleaner. I use it all the time.
Run cleaner then registry cleaner, then click tools uninstall and this should work.
If you have tried to uninstall the errors may come from regitry entries left behind.
Posted on Jul 10, 2010
Code error
Before following the suggestions given below please make sure that you have the latest firmware for your DVD burner drive. Please contact your vendor or visit the manufacturer's website for the latest updates.
Please follow the steps mentioned below to resolve the issue:
1) Empty the contents of the C:\Windows\temp folder and C:\temp folder, if you have one. Then empty Recycle Bin.
2) Defragment your hard drive. DVD video files are very large and can quickly fill your hard drive to capacity. A fragmented hard drive can cause problems during DVD burning. Make sure to defragment your drive(s) regularly.
3) To avoid any compatibility issues, please close all other software and utility applications including virus scans, screen saver and instant messaging software before you launch PowerDirector.
4) Increase Virtual memory :
1. Right click on "MyComputer"
2. Select Properties -> Advance
3. Click on "settings" under Performance.
4. Select "Advance"
5. Click on "change" under Virtual memory.
6. Select "Custom" and enter initial value as "512" and Max value as "3096".
NOTE: If your existing settings are higher than recommended then leave them as before.
5) Please check whether the drive where you have installed Power Director software has enough space on it. At least 15 GB of free space is required and recommended while burning a DVD.
Now, try to burn the DVD at low burning speed.
If the issue still persists, try to uninstall other CD/DVD burning software like Nero, EasyCD Creator, Direct CD etc. Two burning software installed on same computer are known to cause conflict due to common files in them.
Also disable the XP built-in burning software. To disable the Windows built-in burning software:
- Open My Computer.
- Right-click your CD-RW or DVD drive and click Properties.
- Select the Recording tab.
- Remove the check mark from the 'Enable CD recording on this drive' check box.
- Click OK.
Also make sure that the total size of the video does not exceed the disc limit. (It is recommended that the total size should be less than 4.3 GB)
Now, close all other software and utility applications and then try the 'Create a DVD folder' option in the burning options screen and let us know of the result.
If the DVD folder is burned successfully, then the issue is burner specific and not software specific.
If the issue still not resolved, you may need to reinstall the Power Director software. Uninstall other burning softwares and then reinstall Power Director.
Follow the steps given below to reinstall your PowerDirector. Before installing your program, please close your MSN messenger, since we found that MSN messenger my lock some installation programs.
i) Uninstall PowerDirector software:
a.)Start--> Programs -->Cyberlink PowerDirector --> Uninstall PowerDirector
b.)Start --> Run --> type "regedit" --> click "HKEY_LOCAL_MACHINE" --> click
"Software" --> click "Cyberlink" --> "PowerDirector". Delete folder "PowerDirector".
c.)Start --> Run --> type "regedit" --> click "HKEY_CURRENT_USER" --> click
d)Reboot your PC.
ii) Reinstall PowerDirector. (NOTE: Before installation please close MSN Messenger, if open)
Now try again to 'Create a DVD folder'.
Go ahead with burning DVD only if the DVD folder is created successfully and without errors.
Jan 24, 2008 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
How do i download n install free cyberlink dvd suite
My version of Power DVD is 7.0 software. I lost it and had to reload it. I'm not sure if they offer it free on the internet but maybe you know someone that has the installation cd.
Mar 04, 2011 | CyberLink Computers & Internet
No video sound from lg dvd writer when playing dvd movie. player will play cd sound. what is the problem.
I had the exact same problem with my LG model GH22LP20 DVD drive. This is how I solved my problem:
I finally solved this problem. It was a Cyberlink software problem; specifically the software bundled with my DVD which was a Cyberlink Suite w/ PowerDVD2_bing.gif 7.0.
After going 3 - 4 rounds, via email, with Cyberlink tech support in India I finally got them to put down their "100,001 mindless ways to solve a software problem" manual and they emailed me a link to download a slightly newer version of the software; it was Cyberlink Hi-Def Suite, w/ PowerDVD 7.3.
I uninstalled my bundled software, and installed the newer software they gave me. After installing the newer software everything worked perfectly. If you're still having problems and have the same software version I started with, keep bugging Cyberlink tech support (be patient and diligent) until they acknowledge it's a software problem and send you a download link for a newer version. Good luck!
Jan 30, 2010 | LG GH22LP20 DVD±RW Burner
I can't burn anything with my DVD/CD-ROM but it reads dvds and cds
first reinstall the operating system and then you use either nero 6 or NTI CD? DVD maker
Jun 01, 2009 | Computers & Internet
Does cyberlink power dvd burn dvds?
cyberlink power dvd is for playing dvd movies, it is not burning software
Apr 15, 2009 | Dell Cyberlink PowerDVD Software CD DVD...
I can't unistall Media Now CD & DVD Burning Suite
some programs require the disc to uninstall, if the little programs are attached to other programs you will not be able to uninstall them
you can go to start/my computer/go to the program, click on the file icon, that will give you a split screen, you can then look at each detail to see if the little programs are attached to another program
Apr 06, 2009 | Nova Development Media Now CD & DVD...
Cd keys Samsung power DVD XP V4.0 set up
Your software cyberlink power dvd 4.0:
S/N: mv3938m659859834
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 18, 2008 | CyberLink PowerDirector 3 for PC
Computers & Internet Logo
89 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
