Question about Ford Car Audio & Video
After my mechanic fixed a wiper fault,my radio has shut off.and the code isnt on the ford card that came with my car.reg is 07 D 72480
  • Ford Master
  • 4,946 Answers
Remove the radio from the dashboard
Then post theSERIAL NUMBER found on a label on the radio casing
It normally begins with M ++++++
Posted on Jul 11, 2010
Can you give me radio keycode for ford focus 58 reg serial number v051588
Ford V radio codes contact this link: https://www.gumtree.com/p/in-car-audio-gps/car-radio-codes./1200926664 Car radio codes in Uxbridge London Gumtree
Dec 04, 2016 | Ford Cars & Trucks
Location of wiper motor relay
Hi there my name is Brandon I am a mechanical n electronic engineering technician I am the man reg mechanics call when they cant fix something OK to start its not the rely and its not called in... switch!! It is called wiper control switch and its going out or its in a bin
Feb 01, 2016 | Mercedes-Benz 190-Class Cars & Trucks
Hooked battery up backwards
You need to take the Alternator in for a Bench check. The diodes are probably bad. Wiper switch or motor can be bad. Radio can be smoked.
For wiper motor, the contact points use a system where a derailer mechanically shifts the points to break contact. The contacts are probably fused.
Mar 14, 2014 | Ford Escort Cars & Trucks
My windshield wipers wont shut off on my 2011 Ford Transit Connect
Usually the problem is inside the wiper motor. If you can see any contact points or can spray a little WD40 on what you see, it may help. Sometimes backing off the mounting screws and retightening them will allow the grounds to be reestablished.
Feb 26, 2014 | 2011 Ford Transit Connect
My 1995 ford ranger pick up speedometer, radio, break lights, wipers and turn signals dont work
On the ford ranger wiper motor not working, this is how u fix it. I am a licenced autobody mechanic for mercedes and my son bought a ford ranger and of course the wipers were not working-neither did the dome light and door chime.I told my son too replace all fuses ,switch and motor. And still nothing.Remove radio there is a pcm in behind- ours was unpluged. When we plugged it in the door bell would not shut off and the dome light stayed on. In stead of unplugging the pcm remove the light if wd40 does not work on the door latches. And to stop the door bell ringing remove the plastic cover around the ignition and their is a single wire with a blue connector just remove the wire it is the wire closest to the key and tape up the end and problem solved guarenteed . my email is frameman127@yahoo.ca I will walk u through it .
Jul 24, 2010 | 1995 Ford Ranger Supercab
Radio Code for R Reg Ford KA!
give your ford dealership your chassis number or the vin number of your car and they should be able to give you the code for your radio
Oct 20, 2009 | Ford Escape Cars & Trucks
Need radio code for my focus 2001 model y reg
The code could be written down in your manuel, if the security code was not programed in the radio try 0000 to reset. If your really good with the ford dealer that service's your car or the sale's rep that sold you the car, they my have the code still in there system since they always disconnect battery's all the time to work on a car.
If they want to charge you a crazy amount, log onto www.radio-code.com. They can help you by getting the code and cost is cheaper then the dealer or carfax.com may also have the code to your car.
Good luck and keep me posted on how you do.
Jun 01, 2009 | 2001 Ford Focus
05 Ford F150 Radio doesn't work.
I had the same problem and i brought a new ford oem cd player 2 times and my mechanic says its an electrical problem with some fords not the Cd player or the radio. So your cd player may not be junk, it may be electrical or wiring problem.
May 25, 2009 | 2005 Ford F-150
All dash warning lights come on when driving then when i switch off engine it will not turn over ( assume battery flat ) The car is a T plate diesel focus very high miles(255,000) is it worth repairing or...
old fords never die ,and mileage isnt that high ,is the altenator OK .dodgy earth cable from engine to chassis,this fault is a stupid thing and easly fixed ,or is it an excuse to to buy a new car.T reg isnt that a 1978???or have i been out the country too long.
Jan 01, 2009 | 2000 Ford Focus
Car cutting off and the radio ain't working says code
Hi, dont know where you are but i had a similar radio problem after changing battery......... contact your local daewoo dealer ( mine is Dutton Forshaw, Maidstone, Kent. They may be able to help) tell them the problem, they will ask for the chassis no. and the reg no., they will then give you the code that is factory set for the radio that was originally in the car from new. Cutting off could be any number of faults, find a local mobile diagnostic mechanic and ask for a tune up and explain the cut out fault. Sorry i cant help more. steve
Jul 25, 2008 | 1999 Daewoo Nubira
Car Audio & Video Logo
Top Ford Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Ford Car Audio and Video Expert? Answer questions, earn points and help others
