Question about Sport & Outdoor - Others
I have a first generation Savage 110 .243 SN 9xxx that shoots MOA with almost any load. I love it but the trigger pull is very heavy. It does NOT look like any of the trigger assemblies I see on the web. Can it be adjusted? Thanks Art
  • 24 Answers
SOURCE: paslode framing nailer won't shoot
Take 4 bolts off of head . Clean and lube head valve with air nailer oil. Not wd40
Posted on Apr 14, 2009
  • 142 Answers
SOURCE: Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Posted on Dec 31, 2009
agent91
  • 2100 Answers
SOURCE: what is the adjustment increment moa on a 3 x 9
1 moa = 1 inch at 100yards. I think your scope cliks at 1/4 moa.
Posted on Mar 21, 2010
agent91
  • 2100 Answers
SOURCE: moa not true past 300yds tasco 6x24x42mm
The Tasco is not a 600 yrd scope by any means. If you want to get rid of them, there are plenty of deer hunters who will use it at 100 yards and never go beyond that. The MOA is usually imprinted on the windage dial, it will have a little fraction or a decimal there telling what it is at 100 yards. There are a couple good scopes out there, Nikon and Pentax are decent. Leupold is about the best. It will deliver beyond your eye vision and rifles potential. I have a Bushnell on my M-40, mainly because I can't afford a $1000 scope, but I can shoot door knobs off at 200 yards all day. The scope is a piece of junk, but I have it set up right and it works, Hope this helps.
Posted on Apr 27, 2010
  • 11800 Answers
SOURCE: I have A Beeman Silver
No, there is no way to adjust it. Theoretically this rifle uses the "Sporter" trigger : a very simple mechanism with an average pull of just 10lbs - if yours needs more then something is wrong in the mechanism = mechanical failure.
This is not the first rifle of this manufacturer that has come in our shop with mechanical failures, they are very badly manufactured. The only way to fix it is to dismantle it and replace the defective parts - that is simply not worth it, for the same money (around $60) you could buy a new one.
Posted on Jun 04, 2011
Can you explain to me about moas? i got this new p4 and im trying to learn how to use it can you tell me? and do i have to site it in at 100 yards first?
If you are going to attempt to sight in your rifle scope for hunting or just shooting, you will need a basic understanding of what a Minute of Angle is.
Think of a circle as it is divided into 360 degrees.
Each degree is divided into 60 minutes.
Each minute is divided into 60 seconds, but we don't use that for ballistics, seconds of angle are just used in machine shops and in rocket science.
Minute of Angle
1 MOA = 1/60th of a degree
1 MOA = 1.047 inches at 100 yards
Most accurate long range scopes are set in quarter clicks (4 clicks = 1 MOA) or eighth clicks (8 clicks = 1 MOA) but less accurate short range scopes are sometimes set in half MOA clicks (2 clicks = 1 MOA)? which to me is the opposite as it should be.
For a .308 the difference between shooting at 100 yards and at 500 yards is about 11 MOA. That adjustment with a scope using eighth clicks is 88 clicks.
Most accuracy testing is done at 100 yards, because it makes the math easier, and it is close enough to see the bullet holes through a spotting scope.
Folks usually say that 1 MOA is equal to 1 inch at 100 yards, which is almost exactly correct, as 1 MOA is only slightly more than 1 inch at 100 yards. But for what we are doing it is close enough. Now think it on out to 300 yards, 1 MOA is then equal to 3 inches. So if your shots are 1 inch off to the left at 100 yards; out at 300 yards, you will be off to the left 4 inches. Clear as mud? Hope this helps.
Jan 04, 2011 | NcStar 3-12x50e Rifle Scope Illuminated...
Moa not true past 300yds tasco 6x24x42mm
Apr 12, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
My Weaver Classic riflescope is maxxed out for elevation
I don't think the tube holding the cross hairs will go up that high, and shimming the front base, I don't know. What you need is a new cross hair with the dots below the cross, They will raise your line of sight past the 350 zero. Or,,,,, just put the cross at the top of your target, 600 yards without the right scope is a long shot. I hope you have a heavy barrel target rifle in 308 or bigger. My M42 is unbelievable, but, It will shoot better than me all day long and I rarely go over 200 yards. I tried the 600 yard line once, didn't like it. Oh I could hit the target, but I like hitting doorknobs at 200 yards better. What are you shooting anyway? I hope your not trying to stretch out a 223 to the max.
Mar 01, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Generator was running and quit delivering voltage while running. Turned it off and then restarted and checked voltage with no load. no voltage...no smell...plenty of oil...seems like a breaker8000 exl...#...
It very well may have been a breaker that opened up permanently.
But, I bet that the generator was under heavy load for prolonged time, and one / both of the diodes in voltage regulator have opened up. You will have to disassemble the end housing of the alternator to get to these, and then test with multimeter to know for sure.
Of course, your generator may have an electronic controller, and not use diodes / capacitor at all. Since don't have model #, can't be sure.
If engine has dropped much under 1800 (4 pole alternator) or 3600 (2 pole alternator) RPMs, then alternator output would tank or be nonexistent.
Dec 09, 2009 | Generac Electrical Supplies
Buy riflescope!!!! Which one????
Robert, I have the Simmons 6-21x44 MilDot # 511056 scope on my Savage model 10FCP Law Enforcement issue rifle. I think you should check it out. It has 90 MOA internal adjustment and you could get you something like a 15 MOA or 20 MOA tactical rail and push your adjustments out to 1000 meters!!!
Oct 03, 2008 | Nikon Monarch UCC 6.5-20x44 AO Matte
Sport & Outdoor - Others Logo
27 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
