Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
Terrible noise when I try to use the carpet setting
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Make sure your brush isn't jammed. Take it out and clean all the hair off it. That's the motor protector saving your motor making that sound
Posted on Jul 10, 2010
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loud noise with belt protection system On
I'm sorry to hear you're having difficulties with your DC14. The knob you're describing is the brush control, which turns the brushbar on when set to 'Carpets', and off when set to 'Hard floors'. The machine may not pick up hair from carpets if you have it set to 'Hard Floors'.
The brush control system is also designed to make a ratcheting sound to warn you if something is jamming the brushbar. The easiest way to check for and remove any obstructions is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=668&product=DC14-ALLFLOORS_US
Once you've removed any threads, hair and other obstructions from around the brushbar and cleaner head, you should find this resolves the issue. However, if you've tried this and are still concerned, please get in touch with us directly so we can help. You can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 23, 2011 | Dyson DC14 All floors Bagless Upright...
Noise
Hi Linda,
Sounds like clutch problems, try to move the lever for carpet/floor back and forth a few times maybe it will free up. If it still makes the grinding noise, the clutch assembly will have to be replaced. Let me know, i can even walk you through the repair if needed.
Apr 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
After a couple seconds that it is switched to
You need to replace the belt(s). Here are the belts you need and the manual with instructions:
Dyson DC14 Belt
Jan 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
Dec 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Oct 25, 2009 | Hoover Vacuums
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My DC 14 makes a terrible noise when I am vacuuming on carpet, so I put it in the upright postion and it stops. I but down the head and the noise will stop. If I bump the head it will start making the...
If the noise is rattly then it means the drive belt needs replacing, if your model has a protective brush on/off mode on the front plate where you would normally put your foot, it would have to be repaired officially by a repairer. Replacing a protective drive belt can only be done by Dyson repairers or those that repair Dysons.
Jun 17, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Terrible noise when I vacuum some of my carpets
That is the clutch you are hearing and what it is doing is jamming up. Check for anything jammed in the brush, if not you may need to take it in for service to have that replaced or the object is lodged in the clutch itself.
Dec 16, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Nov 11, 2007 | Dyson DC14 Full Access Bagless Upright...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
631 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
