Question about GE 60minute Automatic ShutOff Timer Switch 15069
How to wire to attic fan? Old Sping loaded timer has two wire connections Marked LINE and LOAD . There are two Romex- Three wire cables with Black , White (Common) and bare (Grd) wires coming into this box . There is also one Four wire Romex in the box with an additional Red wire. All grd. wires are grounded to the box, all White wires are connected together. Two Black wires from the 3 wire Romex cables go to the load connection on the switch and the red wire on the four wire Romex. The Black wire from the Four wire Romex goes to line connection on the switch. The old switch only has two connections labled LOAD and LINE ,The New 15069 GE switch has three connections labled LOAD (Red), HOT (Black), and Neutral( White). How should I wire the New switch?
    Novelist:
  • 145 Answers
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Posted on Jul 11, 2010
Im trying to change out my automatic sprikler timer, the new one is Intermatic model T8845PV. Its an old house I have two hot wires going in to the old timer, and I only see one spot for my hot wire in the...
Open following links for resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/images/T8845PV-image-700.jpg
If you have 2 hot wires, then you have 240Volt circuit from breaker box.
T8845PV is 120Volt timer.
How to wire for 120Volt: Use one hot wire to connect to LINE terminal. Cap off other hot wire. Then connect bare ground wire to terminal marked NEUTRAL.
This is not code, but it will work until you have time to run 120Volt line from nearby 120Volt outlet.
Read about 120 and 240Volt circuits
http://waterheatertimer.org/B220C.html
T8845PV is 120Volt timer, made to control 24Volt sprinkler valve.
Inside the timer, there are two wiring terminals marked LINE and NEUTRAL
120Volt cable from circuit breaker has black hot wire and white neutral wire.
Connect black hot to terminal marked LINE
Connect white neutral to terminal marked NEUTRAL
The yellow wires are 24Volt output.
Yellow wires connect to sprinkler valve.
Do not connect 120Volt to yellow wires.
This timer does not have terminals for rain sensor:
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
Jul 31, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
My Leviton 6260M is wired to a bath fan according to the diagram provided: Green wire connected to ground, White neutrals connected together, Black wire connected to 'line' feed wire, Blue wire connected...
Countdown timers are made to work with bath fans.
Leviton countdown timers are stout product with 1HP rating.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#6200
It sounds like timer is bad.
Wiring sounds good. Make sure you don't have Load and Line wires reversed. Try reversing Load-Line wires and see what happens.
Another thing that affects electronic timers is line noise/interference. If replacement timer does same thing, then noise is suspect. Try timer on another circuit without fan. Try another brand timer. Update to newer LTB60 Leviton timer. Use cheap circuit tester from home center to check outlet on same circuit.
Apr 04, 2011 | Leviton 6260M-T Timer Switch 10-20-30-60...
Okay, I have the same problem... It is a cooper combination switch. There are two black wires that are coming out of the back . the instructions don't mention them at all. I am installing a new outlet...
Ok you have GFCI combination switch-plug.
Wires coming out of back of device are connected to "Load" wires.
Load are the black and white wires that go to fan, light, motor.
The black and white wires coming from circuit breaker connect to terminals marked "Line"
Look at back of device for markings.
Black wire from breaker goes to brass screw, white wire goes to silver screw.
There is one more set of screws on device. Device usually arrives with tape over these two screws.
This is what those screws are for: If you are working in a junction box, then three cables enter box.
One cable is for Line wires from breaker box.
Second cable goes to Load (light-fan-motor) that is controlled by switch.
Third cable goes forward to another switch or outlet >> and those wires connect to last set of screws on combo device. Black to brass and white to silver.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Cooper Industries Cooper Wiring 274W...
Two wall sconces: pulled out old dimmer: 2 sets of romex and no ground. white wires wired together; two black wires, one hot. Installed new dimmer: on-off OK but only one light dims with buzzing. Dimmer is...
Okay. This is going to be easy.
You're in the middle of a circuit and that's why you have 2 Romex'.
The HOT black is the line side. It comes from the panel. The not-hot black is the load side. These 2 blacks go to the brass screws on the switch. The whites tie together and don't go to the switch, UNLESS there are 2 silver screws on it, then they go there. Watch the switch to see if it's clearly marked for LINE and LOAD. In that, the HOT black goes to LINE and it's white companion (from the same Romex) goes to the LINE silver screw. The 2 from the second Romex go to the screws marked LOAD.
In the sconces, you're going to find one that has 2 sets of wires and the other has one set. (I'm betting) The one that's working better, is the first one from the switch wiring.
Open the working one with the switch turned off, of course. Disconnect the wiring going to the second light. Make sure the first light works just like you want it to.
Now, take the 2nd sconce down and see if the wires are in the right places. White to white, black to black, grounds in place, protecting wires from the others. If all that looks fine, reconnect the wire running from the first light to the second. Even though these are still opened up. turn on the switch and see if the 2nd sconce works.
If it's still buzzing, try to determine exactly where the noise is coming from.
Some dimmers won't work with florescent bulbs, some don't like halogen bulbs. SOME don't like the energy-efficient curly bulbs!
The box/instructions for the new dimmer may point out what it's NOT compatible with.
If everything's connected correctly and there's still buzzing, I'm guessing that there's some mis-match between the new dimmer and the lights.
Feb 02, 2011 | Leviton Decora Light Dimmer Switch
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
Nov 26, 2010 | Leviton Timer Switch 2-5-10-15 Minutes, 4...
I am trying to replace an old spring loaded attic fan timer. The old time simply had a black line in and a black line out. There was both a white and red line capped off in the box along with a bare...
The timer is wired differently than the old spring-loaded timer.
This is because the timer has an electronic clock instead of a spring.
The electronic clock needs power just like an alarm clock.
The white wire powers the clock.
Here's the wiring.
Black-timer wire connects to Hot-wire-from-breaker
Red-timer connects to Load (attic fan)
White-timer connects to white Neutral
In absence of a Neutral, connect white-timer to bare ground.
If you have your black-timer and red-timer wires reversed, it might cause the symptoms you describe.
Simply reverse the black-timer and red-timer.
If you want to test your wires to make certain:
Remove timer.
Separate wires for testing.
Turn on power.
Use ordinary tester.
Tape tester leads to wood sticks to keep hands away.
Power is ON.
Test each wire to bare ground wire.
When tester lights up, that is hot-wire-from-breaker.
Now test hot-wire to each of the other wires (except ground)
When tester lights up, that is Neutral
Not every switch box will has a Neutral
In that case white-timer connects to ground
Nov 08, 2010 | GE 60minute Automatic ShutOff Timer Switch...
I have an outside light that I want this timer to control. The switch box has a black and a white going out to the light and a black and white with the electricity. The instructions show to hook the red...
You posted under ST01C timer which has 3 wires: black blue and red (no white wire)
Your description seems to say your timer has 3 wires: black white and red
These are two different timers
I'm going to give you two different instructions that are dead-accurate for both types of timers above:
1) Instructions for ST01C and EJ500 Intermatic timers with black blue and red
Lets do the black and white with electricity:
The black Hot wire connects to Timer-black-wire
The white Neutral wire connects to white wire going to Load (to lights)
Now the black and white to the Load (lights)
The black to Load (to light) connects to Timer-blue-wire
The white wires are connected together with wire nut
The red wire is capped off, and used only if you have 3-way switching.
Green connects to bare ground
2) Instructions for all in-wall timers with black, red and white wires (except Aube series timers)
Lets do the black and white from electricity
The white Neutral connects to Timer-white-wire and to white wire going to Load
The black wire to Load connects to Timer-red-wire
all three white wires are connected and covered with wire nut
DO NOT CONNECT RED TO WHITE with any model in-wall timer and then turn on power or it can blow out the timer >>> I just did that while experimenting with the Utilitec 0192773.
Red wire goes to Load on all timers, except with Intermatic ST01C and EJ500
Oct 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
My girlfriend has a leviton illumatech IP106 that keeps "not working". after a number of months. It is operarting a standard dining room 6 light chandelier. A couple of her friends have replaced this in...
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Oct 15, 2010 | Leviton Decora Light Dimmer Switch
I have a Tork 1101. I am confused by wiring diagram. Please help.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
1) Tork 1101 has 120Volt clock motor, making this 120Volt timer.
2) 120Volt circuit has 1 black hot wire and 1 white neutral wire and 1 bare ground wire. Ground wires connect to green screw and to each other.
3) You have two cables, each cable has black, white and ground.
One cable arrives from breaker box.
One cable goes to Load (light, fan, motor, pump etc)
4) Cable arriving from breaker box:
a) Hot black connects to terminal L.
There should be a brass connector plate that connects terminals L and 1. If this plate is removed, then add a jumper wire from terminal L to terminal 1.
b) white connects to terminal X
5) Cable going to Load
a) Load black connects to terminal 2
b) Load white connects to terminal X along with other white wire.
Aug 20, 2010 | TORK Variable Cycling Timer 8601
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
GE 60minute Automatic ShutOff Timer Switch   15069 Logo
386 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
