Question about Crosley CDE6000 Electric Dryer
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
  • 348 Answers
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Posted on Jul 11, 2010
Testimonial: "Thanks, I appreciate this web site! "
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
Dryer won't start.. has power sounds like something binding. long buzzing sound when starter depressed. try once or twice and then nothing for a while. come back try again ..long buzzing sound again
Hi and welcome to FixYa, I am Kelly.
You did not include a make and model number for your dryer so... this is a GENERIC response. With a make and model number we can better help you.
The long buzzing your hearing is the motor winding trying to start the motor. After 30 - 45 seconds if the motor does not start the thermal overload will cycle and prevent further attempts for around 5 - 6 minutes until the motor winding cools down.
Causes of a dryer motor not starting:
1. Binding.
a. Broken dryer fan blade lodged inside the blower housing
b. Motor start switch failure
c. Motor bearing failure
2. Dryer drum bearing / roller problems
a. The drum can be bound up and dragging on internal components of the dryer
b. The Idler pulley bearing may have failed and it is now a brake.
c. Front or rear drum seals failed / pinched against rear or front of the chassis
d. Drum roller bearing failure and is now a brake.
Reach inside the drum and see if you can turn the drum. If you can not turn it with a little effort, you need to find out where the binding is inside your dryer.
This is the best I can do for the moment without a model number. With a Make and Model number I can provide parts listings and item numbers of where to check.
Thanks for choosing FixYa.
Kelly
Feb 06, 2011 | Dryers
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Kenmore Dryer Model 970-C82062-10
The bearing or spindle the drum rotates on is probably bad or worn out. You can get to the back and turn it by hand and feel it when you turn it. You can tell if it is metal rubbing. If so, you can replace it.
Jan 25, 2009 | Kenmore Dryers
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Noisy "rubbing" sound...
it may need a good lubrication job. look for all rolling parts metal or plastics and give a good dose of WD-40 and observe. ba particular to the bushing of the drive motor, the roller and the center bearing that hold the drum.
Feb 17, 2008 | Whirlpool GEW9250 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
491 people viewed this question
Top Crosley Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
jasbo
jasbo
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
