Question about Vivitar ViviCam 2700 Digital Camera
CONNECTION CORDS CANT PLUGIN TO NEW COMPUTER
9 PIN CONNECTOR PLUG NEED TO FIND CANT PLUG INTO SLOUTS NEW COMPUTERS
Part # Description Price Qty 28UC-18000 USB / DB9 Converter / Adaptor with 6 ft USB Cable 23.10
Posted on Apr 20, 2008
How is the power to the monitor supplied? via the computer or via an electrcally plug - I don't see were the connection is on the monitor
The monitor should have come with two cords. One the power cable which will have an electrical plug on one end that is plugged into a wall jack and the other should be one like this.The other end of the electrical plug should plugin somewhere on the bottom of the monitor.
There is another cable that looks like this which is known as a vga cable. Your monitor may take a DVI connector which has a white end and is a larger plug. This will plugin to the monitor and will also plugin to your computer. The place it plugs into the monitor should also be on the bottom of the monitor.
These cables will only fit in one way so you really can't mess anything up. Also the cable between the monitor and the tower are interchangeable it doesn't matter which side you plugin either way will work.
Apr 07, 2011 | KDS K-726MWB Monitor
Only have one serial port on my cpu can the monitor plug be switched
there could be another port for the monitor to use a VGA cable. check and see if your computer is capable of VGA from the port of the back of the computer and if it is. use a VGA cable to connect the computer to the monitor.
Jun 08, 2009 | HP Computers & Internet
Won't turn on with new power supply
Sounds like the switch is out to me or it is mis connected to the motherboard
May 02, 2009 | HP Media Center M370N (DM163A#ABA) PC...
Broken volume and tone remote cord for the SoundSource 3200 Seies
I just need a new connector cord as described. I was hoping I could buy a new one.
But it looks like I will have to take it to an electrical fix it shop somewhere to see if they can fix the pin connector.
Thank you.
Feb 02, 2009 | Manhattan (168670) Computer Speakers
Broken ''pin'', on system connection chord
CHANGE THE CORD AND TRY WITH AMAZON.COM
Nov 27, 2008 | Audio Players & Recorders
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
I need a new power cord for my Lenoxx stereo cassette/ CD player model #CD-102. I hope I am sending this the right way, I am not very good on the computer.
if it is a plugin (socket at the back of the stero) then you need to call the vendor to order the power cord. if it is a build in (internal connected) then you can get any power cord and repair it by opening the stereo and repair the cord.
Oct 20, 2008 | Lenoxx Electronics CD-102 Cassette/CD...
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
No 9 pin video socket
Most video cards use a 15 pin VGA connector.
There is also a 9 pin VGA connector, but they are a lot less common - I'm guessing this is what you have.
Is the video cable hard-wired into your monitor or is it connected via a plug? If it's a plug, is that a 15 or 9 pin? If it's a 15 pin, then all you need to do is buy a new 15-15pin VGA cable.
If it's hard-wired, you'll need to buy some sort of adapter. These are available and don't cost much either, but you might need to try a more specialist computer store to find one.
Hope this helps!
Matt
Feb 29, 2008 | Dell Dim.9150 Pentium D 820 Dual...
Vivitar ViviCam 2700 Digital Camera Logo
37 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
