Question about Canon imageRUNNER 2200
Have forgotten dept code & passwords? how to reset system to print on Canon 2200 copier
  • 1,219 Answers
You need to enter to service mode:
press *
press 2
press 8
press *
choose Copier
under FUNCTION
choose CLEAR
choose PWD-CLR
OK
Turn off/on
Problem solved!
Posted on Jul 11, 2010
Each weekend our canon fax machines stop working. Monday morning we see error code 0322.
This code has something to do with network, I encourage you to contact your IT dept
Jul 05, 2011 | Canon imageRUNNER 2200
Enter DEPT.ID & DEPT.ID Password how can i solve it can any give to reset setting codes
You will have to reset/clear the password. This WILL REMOVE all passwords setup in Dept ID Management. Go into Service mode by pressing the Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, PWD-CLR, Then Ok. You may also use the arrow keys on the display to get to PWD-CLR. Then the RESET key or maybe power down the equipment.
Jun 17, 2011 | Canon Office Equipment & Supplies
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
I would like to Reset/Retrieve Password for Copier Setup Canon, ImageRunner canon ir 2318
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Jun 29, 2010 | Canon imageRUNNER 2200
How to remove a dept id and password - we have several entered into our copier. We want to remove what we have and select a new one.
go to additional functions, system setting's , dept codes and turn them off. if you do not know any dept code's you can reset thru service mode function clear.
Oct 14, 2009 | Canon CLC 1150 Color Copier
How could I set up a password for Canon IR 400S? I have access to Advanced Features but do not see whitch button to tap...
try this : press * with head press the custom setting browse it you will find to activate dept code then you need to have dept code id then password for ex.dept code id -0001 password 9999 you need to enter this two info to open the copy functions hope this will help
Jul 11, 2009 | Canon imageRUNNER 4570 Copier
Canon imagerunner 2200 unlock password code
If its the system admin you need unlocked there is a step to it.
Go into matianence mode>function>clear>PWCLR
POPO machine and you should have no system manager login.
May 15, 2009 | Canon imageRUNNER 2200
How to access IR22016 configuration using IE? i want to setup dept. ID and password using IE.
Print a user data list.
Find your IP address. Enter the IP address into your web browser. This will present you with the RemoteUI interface.
Go to additional functions and select department ID management.
You can also do this on models that have a touch screen by pressing additional functions and pressing the department id management button.
May 06, 2009 | Canon imageRUNNER 2200
Canon imageRUNNER 2200 Logo
343 people viewed this question
old marine
old marine
