Question about Jenn-Air JJW8630C Expressions Collection Electric Double Oven
Front display does not light up
The front display does not light up to show the temp and time
I experienced the same problem. Order a control panel piece and replace it (the clock panel -is what it is referred to on parts list). It is a matter of killing the electrical power, unscrewing the contro panel, unplugging the old panel and plugging in new panel. Takes all of 8 minutes to do. I am a woman and did it myself. Got tired of waiting for the man to do it. Lived with the old panel for about 4 months before deciding to handle it. I found the control panel on line for $146. Appliance repair shops quoted $300 and more to do it - telling me the part itself would cost $275. Save yourself some money and the installation was very easy.
Posted on Dec 26, 2008
I have a neff double oven - When i try to use the top cooker the functions light up when selected then go off. The display shows -5- & the temp does not show on the screen when i turn functions on.
although it looks like a five it means safety activated or to be more precise child lock to switch off turn oven selector switch quickly 3 times off and back on between off and light only this will turn child lock off.
May 25, 2016 | Neff Ovens
How do I fix my GE True temp oven which shows F7 on the display?
https://www.youtube.com/watch?v=Rg7Dp4LBxtA
it seems its the connections ribbons on the control panel is wrong
will give you a clue look down the replys to the video to get more info
some very carefull cleaning is needed inside the front panel rework some connections
i use deoxit 5 and a rag
spray the deoxit to a rag then wipe the connection ribbons
then dowse the plugs with the deoxite
wait a while and re plug then carefully
should cure it
i would add a blob of grease to the sockets once its all running
to avoid further corrossion
hope this helps
Dec 11, 2014 | GE Ovens
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
Dacor Oven Thermostate problem
The replacement temp sensor could be defective.
Mar 03, 2017 | Dacor Ovens
FRONT PANEL DOESNT SHOW THE FUNCTIONS OR TEMPERATURES AS THEY HAVE BEEN RUBBED OFF
mine too, sucks hey?
you can put them back with a engraver, but you will have to go through each function to work out whats what....
you will also need a high temp thermometer to work out the temp settings.
Sep 30, 2012 | Ovens
My thermador double oven display is note openly connected. How do I fix it?
This board set can also be rebuilt at www.fixyourboard.com. Dim display is a common failure that can be repaired reliably at a fraction of the new board cost. Here are the relevant partnumbers :
35-00-760, 12001691, 492071, 14-38-901, 492069, 492067
1065923121 , 1065923160 , 1065923161 , 1065923200 , 1066025120 , 1066025150 , 1066025151 , 1066025160 , 1066025201 , SCD272T , SCD302T , SCE30500W , SCE30600B , SCE70600B , SCE70600W , SC272T , SC301T , SC302T , SMWS72YP AFTER S/N 8204 , SMW272B , SMW272P , SMW272S , SMW272W , SMW272YB AFTER S/N 8204 , SMW272YS AFTER S/N 8204 , SMW272YW AFTER S/N 8204 , SMW272ZS AFTER S/N 8204 , SM272B , SM272S , SM272W , SM272YB AFTER S/N 8204 , SM272YS AFTER S/N 8204 , SM272YW AFTER S/N 8204 , SM272ZS AFTER S/N 8204 , SVD48600B , SVD48600PF , SVD48600PG , SVD48600PK , SVD48600PR , SVD48600PT , S272T , S301T , S302T
Feb 02, 2012 | Thermador SC302T Electric Double Oven
I press the bake button, i choose temp Ie:350 degrees, wait until goes up to temp, next thing you know, it shows 350 but the food is not cooking. press cancel, press bake and 350, temp starts to climb from...
More information is required make model, display type LED, or blue neon red light goes out when on temp, without more info cannot help.
johnf1
May 17, 2011 | Ovens
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Apr 29, 2011 | Lincoln 1132000U - Impringer II Express...
The LED display is barely visible. Both for Timer and Oven Temp.
Problem with Frigidaire CFEB27S2AB2 Electric Wall Oven.
My LED display on my clock has the 3rd number not showing up all the
light. Sample 10:30 the 3 on the top is not light. What is the problem
Jan 07, 2011 | Frigidaire FEB27S5A Electric Single Oven
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air JJW8630C Expressions Collection Electric Double Oven Logo
176 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
