Question about Canon PowerShot S3 IS Digital Camera
Clicking noise when PowerShot S3 lens extends and retracts
I have a PowerShot S3 IS and the lens makes a clicking noise when it extends and retracts. I don't get a lens error and the camera still takes pictures. The repair shop said it was the lens unit and would cost $185 to repair. Worth it or do I continue to use it and run it into the ground while saving for a new camera?
    Brigadier General:
  • 11,967 Answers
Save this for the future if and when a "lens error" appears: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 10, 2010
Hi had to go through all steps but 7 save results. Try resting camera ON its lens, face down on a hard surface. then use #4start method and try on and off 6-8 times. Then give a # 6 a go. Then repeat a few times. I also noticed that when tapping the camera lens down on a glass table i could see the sand/grit reflect oof the glass. This told me that i had a dirt one LOL.
BUT IT WORKED.YEAH
Thanks guys, Marty
Posted on May 15, 2011
How to fix Powershot Elph 530S so that the lens retract all the way when powering off
From the way you describe the problem it appears that the retraction mechanism has become out of line. I think that as you can hear a clicking sound the mechanism is working but not engaging with the lens. Try gently applying slight pressure on the front of the lens this may help to re-engage. You may need to consider a trip to the repair shop.
Jul 11, 2014 | Canon PowerShot Cameras
Lens error
Try the procedures in this tip before taking the camera in for repairs.
Sep 12, 2012 | Canon PowerShot S95 Digital Camera
When i turn on my canon powershot s3 iS , it says lens error restart camera. i tried restarting it , but my when my lens are trying to come out it makes a jammed noise. CAN YOU PLEASE HELP ?!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 13, 2011 | Canon PowerShot S3 IS Digital Camera
My camera is cannon S3 isand its lens came out and now stuckan shows lens errorrestart camera.. need help
Lens probably does not extend or retract because of debris or misaligned gear box. The lens can many times be repaired without having to replace it. Try to return to manufacturer. If you're out of warranty, there are third party place that fix them such as camera lens repairs. There are also free camera repair guide websites that show you how to replace the lens, the part is usually available on ebay.
Jul 05, 2010 | Canon PowerShot S3 IS Digital Camera
The lens will not retract. A message says "lens error, restart camera," but the camera will not restart. The camera is a Canon PowerShot S3 IS. I can hear a "whirring" or motor noise when I try to start...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some simple things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 17, 2010 | Canon PowerShot S2 IS Digital Camera
Was shooting with Canon PowerShot S3 IS and the lens won't retract,screen says lens error,restart camera. I have restarted camera, changed batteries etc... still nothing. You can hear a clicking sound like...
The lens mechanism had probably got some dust, sand or grit jamming it and stopping it from retracting. Sadly the lens will be difficult to repair yourself as it needs to be completly stripped from the camera. Find a good repair shop and get a quote locally.
Feb 08, 2010 | Canon PowerShot S3 IS Digital Camera
Lense is extended but will not retract combined with a clicking noise....error code E18
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 23, 2009 | Canon PowerShot S2 IS Digital Camera
Canon G9 dropped
I was told it happens when the battery is low
Aug 20, 2008 | Canon PowerShot G9 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
482 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
