Question about Proscan PS52800 52" Rear Projection Television
Model number pPS52650 ;supershield number SSH516
Back ground turns orange and sometimes green
2.7l engine, left bank at rear of engine on top of intake. two wire connector orang w/green strip and black wire. what/where does it connect to
Could be many things. Orange/green is a power wire, black is ground. Black could be a engine ground or ECM ground. Orange/green is power. 12 Volts. Check engine light on? If not, some plugs don't go to anything. They use one harness for many different models. Yours may not have this option.
Aug 07, 2015 | 2004 Chrysler Sebring
84 honda shadow front running lights replacement: new running lights have different color codes (red, black & back/white)... which wires go to the existing wires which are: orange, orange/white &...
As the wiring on aftermarket signals is not standardized, you will need to determine which wires are ground, running, and turn respectively. If you can disassemble the signal, the ground will be connected to the outside of the socket, and the other two will be running and turn. If you cannot disassemble the signal, or have access to a multimeter, you can determine which wire is ground by checking continuity between the outer socket and wires. Your stock green wire is the ground, and the orange/white is running light. If when you hook the wires up, your running light is brighter than the turn signal, switch the leads.
Hope this helps.
Aug 20, 2010 | 1984 Honda VT 500 C Shadow
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Can't turn on ipod shuffle
Try To Plug It Into The Computer.. This will Sometimes Turn It Back On
May 06, 2010 | Apple iPod shuffle Second Gen. Silver (1...
THE CAR WONT START AND THE ALARM IS ACTIVATED IS THERE A WAY TO BYPASS OR RESET ALARM
sometimes disconnecting the battery works, also look in your owners manual. sometimes you can turn it off by a sequence in how you push buittons on the radio on your car.
Mar 11, 2010 | 1994 Chrysler LHS
My Toshiba Regza 32 inch lcd tv has a serious problem, on occasion the screnn will turn a fuzzy green color and turn itself off, usually a few loud popping noises also occur after it shuts off then the...
Model number means EVERYTHING to a real technician...
As a guess the popping noise could be arcing to ground - maybe from the inverter or one of the transformers on the inverter. The fuzzy green could be decoding the t-con board is attempting as this ground fault happens and shuts the unit off... I' would clearly have this checked before it does some serious damage. An ounce of prevention could save you pounds of cure....
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Toshiba REGZA 46RV530U LCD TV
My printer flash green then oranfe and again and
5 times says the feed roller is not turning properly, sometimes the gears break and other times something falls in the back and stops the roller from turning. It's a different error if the orange flashes 5 times, or if it flashes orange and green 5 times.
Sep 01, 2009 | Canon BubbleJet i560 InkJet Printer
Need wiring diagram for harness
1) Black Ground
2) Red 12V Ignition
3) Yellow 12V Constant
4) Orange Illumination
(Sometimes there's an extra orange for cell phone mute)
5) Blue Remote
6) Blue/White Power Antenna
7) White Front Left
8) White/Blk Front Left
9) Gray Rear Left
10) Gray/Blk Rear Left
11) Green Front Right
12) Green/Blk Front Right
13) Purple Rear Right
13) Purple/Blk Rear Right
May 04, 2009 | Car Audio & Video
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Proscan PS52800 52" Rear Projection Television Logo
37 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
