Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
No signal on t.v
All the t.vs in the house work so it not the house signal but this one tv saids it has no signal and i dnt know what to do can u please halp me
thank you
  • yaaa1 May 02, 2008
    its unable to turn 'on with either remote or mannually, no signal the red light keep flashing when you press the power button, what do i do to fix this problem
  • 1,224 Answers
Might need to replace signal component inside the tv these usually ware out along with bulbs rouitine maintenance it what it requires
Posted on May 07, 2008
When connected to cable, get a no signal indicator
You need to go into the TV menu, locate where choices for choosing incoming signals are, and choose the cable option, so the TV knows that it is receiving a cable signal, VS an antenna signal.
Nov 16, 2014 | Vizio 32" E320I-A0 LED-LCD Smart TV, Black
No signal even on the main house arial which currently works for other Tv's.
check to make sure set is on correct input and let me know.
Mar 13, 2012 | Televison & Video
I have a 15" LCD
Yes, because the TV tuner is analog and won't decode digital broadcasts. m@nt
Dec 20, 2010 | Audiovox FP1520 15 in. LCD Television
Cable company switched to digital, now my Ant A port on the vs-50603 does not receive signals. I can somewhat view the analog signals through my PIP only. other tv's in the house came back with signal 5...
When the cable company offers you digital cable, you typically need a cable box to unscramble the digital channels. Therefore you need to connect either a coaxial cable from the cable box's RF output, if it has one, or connect 3 RCA cables from the yellow, white and red jacks on the rear panel of the cable box to the TV. Analog channels only (if available) will go straight thru over the coaxial RF hookup. They are not scrambled. Select the proper input source on the TV for the cable box.
Aug 26, 2010 | Mitsubishi VS-50603 50" Rear Projection...
Vizio TV with "No Signal" floating on screen
Tries take out the HDMI cable and replug it back in the HDMI socket.Unplug the Directv power plug and replug,press the off/on botton on again to reboot the signal.Should be every back to normal.
Sep 29, 2009 | Televison & Video
RE: vs-45607
Good Day, chefkenny;
I don't think you will need the manual to perform this task. Like I stated the concern is on the signal board. Looking at the TV from the back the signal board will be on your left, the parts of concern will be on right side of "signal" PCB, toward the center of said board. You can see part location numbers easier from the bottom.
Good Luck, big IRISH.
Aug 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Plasma TV Reception
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
Jul 21, 2008 | Televison & Video
Mono Vs Stereo
Here is what I found out. I had this same problem. I have cable TV and the signal coming into my house was not very strong. They 'boosted' the signal and this problem stopped. Along the way, they tested that the cable line had been passing through a splitter, so that to the house the signal was good, but by the time it passed all of the splitters, the signal was not strong enough. Now all is well and the problem does not happen anymore.
Nov 12, 2007 | Akai LCT3201AD 32 in. LCD Television
Mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Jan 06, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
