Question about Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile
Is my 96 EFI 580 a 12 Volt Pos. It won't start Battery seems low.
    President:
  • 1,978 Answers
Early EFI models require a strong battery to start.
Posted on Jan 16, 2011
Battery will not charge on Farm 1940 Farmall Cub Tractor it is not a lawn mower
check voltage at with tradtor running pull off pos side of battery see if your getting voltage for 6 volt 6.5 to 7.5 volts for 12 volts 12.5 to 13.5 if low voltage go to voltage regultor if volt or low go to generator test there if low replace gen if voltage ok generator replace voltage regulator
Sep 02, 2014 | Garden
2007 ford f150 will not start. IGNITION DOES NOT BUZZ WITH KEY IN, GEAR WILL NOT SHIFT. LIGHTS WILL TURN ON. THE STARTER HAS BEEN DRAGGING. DOES NOT CLICK WHEN I TURN THE KEY. WHAT COULD MY PROBLEM BE
Pull off the neg and use jumper cables connected to another vehicles battery. Attach the jumper normally on the other vehicle, attach the Pos to your battery pos and then attach the neg jumper cable to the disconnected neg cable on your truck. My suspicion is that your battery may test well with a volt meter but cannot take any load on it. It should be floating at 13.5 to 13.8, not 12vdc.
Jul 21, 2014 | 2007 Ford F-150 Regular
How do you wire up 4 6 volt batteries in a 1976 kenworth. 12 volt lights 24 volt starter
When you go pos to neg from one battery to the next it increases voltage, pos to pos just increases amperage. You would want to wire 2 in series, just imagine stacking batteries in a flash light, pos from one to neg on next. Remaining pos and neg are 12v now. Run both remaining pos to starter and ground both negs. your pushing a lot of amps with the batteries and doing 12v, and your charging system is 12v. If you do another series from there, you have to regulate the voltage when the starter kicks in...you risk burning every light and electric component...just like running 12v in 6v system... You can also use 4 12v batteries and run all pos to pos and all neg to neg and have mega cranking amps...that is how all modern big trucks are set up. Your pushing around 7k cranking amps that way(1500 per battery)...plenty to start the healthiest cat... And don't have the worry of dual voltages or running in series. You really don't need 24v to start and unless you have a 24v alternator, these are your 2 options. Best bet if your not sure is to try with 12v...no risk of frying anything even on 24v system. 24v on 12v system is, on the other hand, a big risk. 43bf17ec-4e37-4a15-a147-d1e7a1377d9f.jpg
Jun 03, 2014 | Cars & Trucks
P1001 System Relay Coil Open/Low EFI on 2002 FLHTCI Problem's & Solution's
Hi Anonymous, check your system relay switch for evil graft and corresion and poor connections, clean and apply soothing dielectric grease. Check ignition switch for nuclear melt down, and you can try a voltage drop test between battery and fuel pump, should be no more than 1/2 volt difference. Good luck
Apr 01, 2014 | 2002 Harley Davidson FLHTCUI Electra Glide...
CHECK ENGINE LIGHT COMES ON AT START UP AND IDLE. NO ROUGH IDLE NO SYMPTOMS?????
Have you pulled the error codes?
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
What do the codes mean?
DTC FAULT CONDITION MODULE
"BUS Er" (TSM/HFSM) Serial Data Open/High
B0563 Battery Voltage High (TSM/TSSM)
B1004 Fuel Level Sending Unit Low (Instruments)
B1005 Fuel Level Sending Unit High/Open (Instruments)
B1006 Accessory Line Overvoltage (Instruments)
B1007 Ignition Line Overvoltage (Instruments)
B1008 Reset Switch Closed (Instruments)
B1121 Turn Signal Will Not Flash (HFSM)
B1122 Right Turn Signal Open (TSM)
B1123 Left Turn Signal Short-to-Ground (HFSM)
B1124 Right Turn Signal Short-to-Ground (HFSM)
B1125 Left Turn Signal Short-to-Voltage (HFSM)
B1126 Right Turn Signal Short-to-Voltage (HFSM)
B1134 Starter Output High ((TSM/TSSM)
B1135 Accelerometer Fault ((TSM/TSSM)
B1136 Accelerometer Tip-Over Self Test (HFSM)
B1141 Ignition Switch Open/Low (HFSM) ONLY
B1141 Turn signals Will Not Flash (TSM) ONLY
B1142 Internal Fault (HFSM)
B1143 Security Antenna Short-to-Ground (HFSM)
B1144 Security Antenna Short-to-Battery (HFSM)
B1145 Security Antenna Open (HFSM)
B1151 Sidecar BAS Low ((TSM/TSSM)
B1152 Sidecar BAS High ((TSM/TSSM)
B1153 Sidecar BAS Out of Range ((TSM/TSSM)
B1154 Clutch Switch Short-to-Ground (TSM/HFSM)
B1155 Neutral Switch Short-to-Ground (TSMHFSM)
B2006 Radio Switches Shorted/Stuck (Audio)
B2007 Handlebar (Audio) Switch Shorted High(Audio)
Handlebar Mode Switch Shorted High(Audio)
Handlebar PTT/Squelch Switch Shorted High(Audio)
B2008 Handlebar (Audio) Switch Shorted Low(Audio)
Handlebar Mode Switch Shorted Low(Audio)
Handlebar PTT/Squelch Switch Shorted Low(Audio)
B2009 Handlebar (Audio) Switch Stuck or Open(Audio)
Handlebar Mode Switch Stuck or Open(Audio)
Handlebar PTT/Squelch Switch Stuck or Open(Audio)
B2010 Passenger (Audio)/PTT Switch Shorted High(Audio)
Passenger Mode Switch Shorted High(Audio)
B2011 Passenger (Audio)/PTT Switch Shorted Low(Audio)
Passenger Mode Switch Shorted Low(Audio)
B2012 Passenger (Audio)/PTT Switch Shorted Stuck or Open(Audio)
Passenger Mode Switch Shorted Stuck or Open(Audio)
B2013 Sidecar Switches Shorted High(Audio)
B2014 Sidecar Switches Shorted Low(Audio)
B2015 Sidecar Switches Shorted Stuck or Open(Audio)
B2016 Front Speakers Shorted(Audio)
B2017 Front Speakers Open(Audio)
B2018 Front Speakers Shorted to Ground(Audio)
B2019 Front Speakers Shorted to Battery(Audio)
B2020 Rear Speakers Shorted(Audio)
B2021 Rear Speakers Open(Audio)
B2022 Rear Speakers Shorted to Ground(Audio)
B2023 Rear Speakers Shorted to Battery(Audio)
B2024 Sidecar Speakers Shorted(Audio)
B2025 Sidecar Speakers Open(Audio)
B2026 Sidecar Speakers Shorted to Ground(Audio)
B2027 Sidecar Speakers Shorted to Battery(Audio)
P0107 Map Sensor Open/Low (EFI)
P0108 Map Sensor High (EFI)
P0112 IAT Sensor Voltage Low (EFI)
P0113 IAT Sensor Voltage Open/High (EFI)
P0117 ET Sensor Voltage Low (EFI)
P0118 ET Sensor Voltage Open/High (EFI)
P0122 TP Sensor Open/Low (EFI)
P0123 TP Sensor High (EFI)
P0131 Front O2 Sensor Low (EFI)
P0132 Front O2 Sensor High (EFI)
P0134 Front O2 Sensor Open/Not Responding (EFI)
P0151 Rear O2 Sensor Low (EFI)
P0152 Rear O2 Sensor High (EFI)
P0154 Rear O2 Sensor Open/Not Responding (EFI)
P0261 Front Injector Open/Low (EFI)
P0262 Front Injector High (EFI)
P0263 Rear Injector Open/Low (EFI)
P0264 Rear Injector High (EFI)
P0373 CKP Sensor Intermittent (EFI)
P0374 CKP Sensor Synch Error (EFI)
P0501 VSS Low (EFI)
P0502 VSS High/Open (EFI)
P0505 Loss of Idle Sped Control (EFI)
P0562 Battery Voltage Low (EFI)
P0563 Battery Voltage High (EFI)
P0603 ECM EEPROM Error (EFI)
P0605 ECM Flash Error (EFI)
P0661 Active Intake Solenoid Open (EFI)
P0662 Active Intake High/Shorted (EFI)
P1001 System Relay Coil Open/Low (EFI)
P1002 System relay Coil High/Shorted (EFI)
P1003 System relay Contacts Open (EFI)
P1004 System Relay Contacts Closed (EFI)
P1009 Incorrect Password (EFI)
P1010 Missing Password (EFI)
P1351 Front Ignition Open/Low (EFI)
P1352 Front Ignition Coil High/Shorted (EFI)
P1353 Front Cylinder No Combustion (EFI)
P1354 Rear Ignition Coil Open/Low (EFI)
P1355 Rear Ignition Coil High/Shorted (EFI)
P1356 Rear Cylinder No Combustion (EFI)
P1357 Intermittent Secondary Front (EFI)
P1358 Intermittent Secondary Rear (EFI)
P1475 Exhaust Actuator Position Error (EFI)
P1477 Exhaust Actuator Open/Low (EFI)
P1478 Exhaust Actuator Shorted (EFI)
U1016 Loss of ICM/ECM Serial Data (Instruments)
U1016 Loss of Serial Data(Audio)
U1016 Loss of ECM Serial Data (TSM/HFSM))
U1064 Loss of (TSM/TSSM) Serial Data (EFI)
U1064 Loss of (TSM/TSSM/HFSM) Serial Data (Instruments)
U1097 Loss of Speedometer Serial data (EFI)
U1255 Missing Message at Speedometer (EFI)
U1255 Serial Data Error/Missing Message (EFI)
U1255 Serial Data Error/Missing Message (Instruments)
U1255 Serial Data Error/Missing Message (TSM/TSSM/HSFM)
U1300 Serial Data Low (EFI)
U1300 Serial Data Low (Instruments)
U1300, U1301 Stalls, then Starts(Audio)
U1300 Serial Data Low (TSM/HFSM)
U1301 Serial Data Open/High (EFI)
U1301 Serial Data Open/High (Instruments)
U1301 Serial Data Open/High (TSM/TSSM)
U1302 Infotainment BUS Shorted Low/High(Audio)
U1306 Infotainment BUS Lost Communications with Hands free Phone Module(Audio)
U1307 Infotainment BUS Lost Communications with CB Module(Audio)
U1313 Infotainment BUS Lost Communications with XM Module(Audio)
U1314 Infotainment BUS Lost Communications with Navigation Module(Audio)
U1317 Infotainment BUS Lost Communications with High Output Amplifier(Audio)
Jan 31, 2014 | 2007 Harley Davidson FXDB Dyna Street Bob
How to jump a BMW 320
All vehicles with a 12 Volt Positive system are jump started in the same manner.
If done properly, you should always connect the +Pos side on the battery in the vehicle that should be running, then connect that same cable to the +Pos side on the low battery. Then, you connect the
-Neg side on the running vehicle, and now connect the other -Neg end to a solid ground on the vehicle with the low battery. You really want a good connection for this on a solid part of the engine/trans., since when you attempt to start the car, it will be drawing 400-700 Amps.
(Alternator bracket, exhaust manifold, a sling point, etc. wil do.)
Some people hook to the -Neg side of the low battery, but that can cause sparks as well as an explosion if hydrocarbons are coming out of the low battery.
A completely fried battery can cause the vehicle providing the jump start to stall and can even damage components if not connected properly.
Mar 29, 2012 | 2006 BMW 320 Ci
Won't start every time, when it does runs rough
test fuel pump pressure seems like its faulty i think your right
Jan 03, 2010 | 1996 Ford F150 Regular Cab
Dead battery .9a with pos. term. disconnected unplug radio fuse drops to .4a also unplug batt main fuse drops to .02a
FIRST CHECK TO SEE IF YOUR BATTERY CAN ATTAIN & SUSTAIN A FULL CHARGE FOR 24 HRS, IF NOT REPLACE BATTERY. IF OK, DISCONNECT POS TERMINAL, HOOK UP VOLT METER SEE IF YOU HAVE MORE THAN 8 VOLT DRAW IN THE SYSTEM, IF SO START PULLING FUSES TO LOCATE EXSESSIVE DRAW ON BATTERY.
Oct 30, 2009 | 2004 Pontiac Montana
My son's 96 grand cherokee kill's the battery when engine is shutoff and also when running the volt meter will be o.k. for a bit and then nose dive to 0 volts. had alt. checked o.k.. seemed to start acting...
start the vehicle up and unhook the pos cable from the battery if it dies its going to be a bad alternator or the battery has gone bad.one sure way to know if its the alternator is to un hook the pos cable while the car is running.they can test good even when they arent.
Aug 18, 2008 | Jeep Grand Cherokee Cars & Trucks
Interactive Toy Concepts Crossfire Arctic Cat Rc Snowmobile Logo
164 people viewed this question
Top Interactive Toy Concepts Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
