Question about Bodyguard T240 Treadmill
Bodyguard T240 wont start
I have a bodyguard T240 treadmill and it will not start. None of the lights will even flick on?
    President:
  • Bodyguard Master
  • 832 Answers
To use these instructions, you need to have a familiarity with electricity and a working knowledge of a voltage multimeter. With all of these tests, USE EXTREME CAUTION!!! Never let the voltage ground directly to any part of the treadmill or your leads ground while you are testing voltage.
1) To begin, set your volt meter to AC volts. We are going to trace the power from the wall outlet through the treadmill to see where it ends.
2) With the treadmill unplugged, test the wall outlet. You should have from 115 to 125 VAC. Optimally, you will have at least 120 VAC.
3) Follow the power leads from the power cord to the lead ends. With the treadmill unplugged, connect your meter to the lead ends. Plug the treadmill in and check your reading. It should be the same as your reading from the wall outlet.
4) Continue this process with the electrical system, following the leads, as they pass through, breakers, fuses, and the like.
5) Where the power flow ends is where your problem is. Sometimes it will be in a bad connection, sometimes it will be in a shorted breaker or blown fuse, at times it may be as simple as a safety switch not working properly, or it may be a major problem with a component.
6) In some cases, components work in tandem (i.e.- a controller may need a signal from the console computer to release voltage to the motor.
TESTING FUSES, BREAKERS, WIRING, AND SWITCHES
1) One of the most common problems with power outages is problems with fuses, breakers, wiring, or switches.
2) If your treadmill is equipped with a safety switch, set your volt meter to continuity. Touch your test leads together to make sure you are getting a closed circuit. With the treadmill unplugged, back the leads off the safety switch, usually near the upper display computer. With the safety key out, test the switch. It should be open. Push the safety key in. Your circuit should be closed. If this tests ok, move to the next step.
3) While testing for voltage, you can unplug your treadmill and test the fuses, breakers, and wiring harnesses. Sometimes a breaker may have shorted open and not tripped. Test these components individually. You want a closed circuit on all of them
Posted on Jul 20, 2010
Cost s&w Bodyguard 380
If you wish to get some details then check the following link.
http://electro-medical.blogspot.com/
Nov 04, 2016 | Bodyguard Exercise & Fitness
Treadmill belt doesn't run smoothly
First of all lubricate the treadmill. If it didn't workout then try to tension the walking belt.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
https://www.youtube.com/watch?v=b1MU7MvBETs
https://www.youtube.com/watch?v=JC72OIKdluY
Dec 27, 2015 | Bodyguard T240 Treadmill
Need schematics for bodyguard model 8600
see the diagrams attached. God bless you
Oct 09, 2013 | Bodyguard Exercise & Fitness
Does anyone know where I can get a manual for my BodyGuard T280 treadmill. It's a 2005 model
Dear Sir:
Please to the next web site:
www.manualsfactory. com + fitness.manualsonline.com+www.iconservice.com
for free download.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 09, 2012 | Exercise & Fitness
Where can i get a replacement safety clip/magnet for a bodyguard T300 treadmill
Call them directly @ 1-800-373-2639 and ask for service department. This is a French Canadian company all prompts will be in French first then English. Very professional and knowlegable people
Sep 28, 2010 | RTO Bodyguard T300 Commercial Treadmill
My bodyguard t240 says i need to calibrate it. its a slightly older modle and i cant seem to find the maual
Turn the on/off switch to off.
Hold down the "speed increase" and "speed decrease" buttons while turning on the switch at the same time. You will be in the "diagnostics" menu. Scroll to the "elevation calibration" option.
I know, it is an older post.
Aug 10, 2010 | NRS Bodyguard® T240 Treadmill
Bodyguard T240 Treadmill Logo
373 people viewed this question
Top Bodyguard Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Bodyguard Exercise and Fitnes Expert? Answer questions, earn points and help others
