Question about Element ELC-HS321 32 in. LCD TV
Sound How do I get sound for extra speakers with the audio out jacks? When I plug speakers in, no sound comes out.
  • Element Master
  • 5,344 Answers
Except for the Headphone jack (mini-jack) and the coax audio, all of the audio jacks are audio IN. Which jack do you have your speakers connected to? The headphone jack is on the side next to the coax connection (ANT) and the coax audio out is at the bottom of that set of side jacks. The headphone mode should automatically cut the TV speakers. The coax audio out is set up by pressing Menu and then using the down arrow to highlight Audio. Then press the right arrow button to enter the submenu. Press the up or down arrow to reach SPDIF. Then you use the left and right menus to select PCM, Digital Dolby or OFF.
I hope this helps.
Posted on Jul 10, 2010
No suround sound from my pioneer vsxd510
You have to use the Audio Deck or something like that, a software that is provided with your sound drivers. I had VIA sound drivers & I was provided with VIA HDeck (or something like that) I used it to fill sound into the rear speakers without plugging any extra Jack (only the green one)
You can also do this, right click on the volume button on the bottom left corner. Click on Playback Devices > Speakers
click on the Configure button on the bottom left corner of the dialog.
Choose your audio configuration.
Stereo ( 2 Speakers)
Surround (more than 2 Speakers)
Hope this helps.
Jul 07, 2013 | Audio Players & Recorders
No sound, despite the PC saying the speakers have been configured. When I plug them into a different jack the PC tells me which the correct jack is but I get no sound - have tried all the jacks.
Go to control panel, click sounds and audio devices then a window will pop up under speaker settings will be a picture of 2 speakers. Click advanced and set it to desktop stereo speakers. Turn your computer around and plug them into the green 3.5mm sound jack. That should work if not then there is something wrong with your computer's audio driver or sound card. I would check for updates for your sound driver and that should fix it. If not i would try buying a new sound card
Sep 24, 2010 | Logitech LS-21 2.1 Speakers
I have a 42 inch sanyo tv I am trying to hook up saround sound or just extra speakers
Extra speakers without having the external speaker jacks in the rear is definitely a NO NO. The surround sound is used by connecting the RCA jacks from the TV that say Audio Out to the surround sound audio input on the receiver.. The RCA cables are cheap, you can get them at Home Depot ect....
Nov 27, 2009 | Sanyo Televison & Video
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
Is my sound card fried?
hmm ,,,r u not geting sound ,,well try download the sound drivers ,,you can download the sound drivers from this website sound drivers ---> http://www.softwarepatch.com/utilities/ac97.html and http://www.softwarepatch.com/utilities/ac97.html
Jan 13, 2009 | Computers & Internet
Stereo Speaker troubleshooting
It sounds like the audio jack itself has internal damage. Depending on how it is mounted on your laptop case, or possibly on an internal circuit board inside the laptop; it might be possible to repair the jack or replace with a new 1/8" audio jack. Some soldering skill may be required after disassembling the laptop and getting access to the jack.
Jan 12, 2009 | Computers & Internet
Static coming from my DELL AS500 speakers
It's the jack on the back of the PC or sound card. Sounds like some solder is loose on the jack.
The cheapest solution would likely be to just replace the sound card, if your comfortable installing them. It's really quick and pretty hard to mess up.
If it's "onboard" sound, meaning the audio jacks are built right into the mother board, you'd likely need to just replace it with a pci based sound card.
Dec 06, 2008 | Dell AS500 Sound Bar Computer Speakers
How does Logitech X-540 speakers connect to a laptop? Do you connect them through the headphone jack? Do you need to buy any extra cables?
see it is a 5.1 speaker system if your laptop comes with 3 audio jacks with colours green black and pink then all your speakers works if you have only two jacks tht is one jack for audio and other is microfone then u only your woofer and 2 speakers works in speaker cables ther will be two cables connect the green one to green jack your sound plays if u have totally 3 jacks connect the 2nd cable to black one(non microfone jack)check this out this works
May 07, 2008 | Logitech X-540 Computer Speakers
Soundcard problem on D530 SFF
Sounds like the audio return wires aren't connected. On the motherboard, there is a sound jack on the back left side of the mobo. The jacks from the front audio panel connects to it. Both the Left and Right channel have an out and an in connector. These send the signal to the headphone jack on the front panel and return the signal to the rear output jack if a headphone is not connected. Look for looe or broken wires. The other spot to check is the front headphone jack. If a headphone plug was pulled out or pulled sideways, it could break the solder joint on the PCB panel or break the shunt feeding the singal to the rear jacks. Hope this helps.
Ron
Apr 13, 2008 | HP Compaq Business d530 PC Desktop
Element ELC-HS321 32 in. LCD TV Logo
377 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
