Question about Kenmore 24922 Top Load Washer
Turns on can hear motor but won't dispense water and won't agitate
  • Kenmore Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machineturns on can hear motor  but won't dispense water - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jul 12, 2010
Motor is running but won't agitate and belt is on ? I can hear the motor humming and it will fill up but it wont agitate.
Check drum turning by hand ok not sticky sounds like could be motor if it hums and no turn..
Oct 18, 2014 | Hotpoint Washing Machines
If it fills with water but won't wash, is it the timer
hi mary,i just wrote and asked you for the model number,if this is a regular top load washer it could be the timer as long as you don't hear the motor running,if you do hear the motor running you could have a broken motor coupling because the drain pump is on the motor shaft so it will drain,
http://www.youtube.com/watch?v=9K1KHEogf3c
if you don't hear the motor it could be the timer,when it should agitate try tapping on the timer and see if it works,it has points in it and they can get stuck together or burn out and have no contact like you're saying but it's just a guess without seeing it but if the timer is advancing through with no agitation it could be the timer,did you try any other cycles
Apr 02, 2013 | Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
There is no water coming out of the water dispenser. I changed the filter and check the water line coming from the pipe, there is water coming thru the water line. when I push the water dispenser lever I...
Well, there is no "motor" for the water dispenser, only a solenoid valve. However, there could still be a problem with the solenoid even if you do hear it when its energized. Hearing it make a noise does not mean its working properly.
Aug 13, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Kitchenaid side by side frig (KSCS25IN) will not dispense cubes
Check the drive gear for the agitator, It might have gotten stuck on ice too many times and stripped the gear. Good luck!
Sep 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE refrigerator GSS25JFMCWW not dispensing ice but dispense water
I have the same problem with the same unit. I removed the ice tray and held the open door cut-off switch closed. I then pressed the lever to dispense ice. I hear a humm like power is getting to the motor but the motor is not turning. I hear a click like the selonid is engaging. I'm having to assume at this point it's the motor and I am going to go ahead and order a motor. I've found a motor for the unit at partselect.com for $65.54. Hope this helps you.
Apr 21, 2009 | GE GSS25JFM Side by Side Refrigerator
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Kenmore 24922 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
