Question about Bialetti 20-9 Stove Top Espresso Machine
I left it on the burner. It melted the handle off and the ring is smooshed. I have had it forever. Use it everyday. Should I buy a new one or repair this one.
LEFT REAR BURNER GETS HOT WHEN OVEN IS ON
Look at this as an asset. The oven vents to that location. (gotta vent somewhere). You can use the heat to melt butter, keep something already cooked warm like the potatoes, dry pans after you've washed them... I like this feature!
Sep 11, 2014 | Whirlpool Kitchen Ranges
Craftsman circular saw 7 1/4" broken handle
You can buy the handle for 11.59 per side (left and right halves) you can buy them from: www.searspartsdirect.com They have substutited a new part (probably better one) You would have to decide if 25.00 is worth it to fix your saw. You could buy the part and fix it yourself. A new saw like this one is probably not more than 75.00
Jul 18, 2010 | Craftsman Saws
HOW DO I CHANGE FLUSH SEAL ON KOHLER ONE PEICE TOILET
The flush seal is the rubber gasket between the tank and the bowl. You do not have one. So I am guessing you mean the wax ring on the floor?? They usually only get replaced when the toilet is changed, unless you spring a leak. Or are you talking about the flapper inside the tank that holds the water till the flush lever is pulled? Get a new flapper, if it is just the flapper you need, otherwise you will have to buy the whole thing, all these parts are available at the hardware store. I think it is held on by a couple screws in there, might just be a press fit, we don't see too many one piece toilets. And the wax ring is about $2, but the toilet has to be unbolted from the floor and water disconnected, clean off the old wax, put on the new ring, smoosh it back down and bolt it back it up. Don't for get the water line. Check to make sure you have no leaks. Hope this helps.
May 23, 2010 | Kohler K-3386-0 Rialto one-piece...
Need to fix a leaking delta shower faucet and need to know how to take it apart. Single handle. only turns to left for on and farther left the hotter it gets,
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
Mar 31, 2010 | Delta & Single Handle Shower Faucet
Tiled bathroom floor. Went to install toilet
hi, the tile is supposed to go under the toilet flange (the thing you put the wax ring on), very common "oops", can be rectified by placing another wax ring right on top of the first on. best to make the first one a "horn type" wax ring, then put the plain one (no horn) on top of first and try to smoosh it on just enough to stay in place so when you install toilet it doesn't move,.....cheers!
Jan 31, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Multiple burners turning on
You have wires that have melted and fused together giving you the result that you describe. If you are mechanically inclined you can make the repairs yourself, if not, hire a pro as you can get a serious shock. Get back and let me know how you make out.
May 20, 2009 | Amana AKT3040 Electric Cooktop
New house . tub wont turn off. water has a steady
The plumber soldered in the faucet without removing the cartridge, the o-rings are melted. Have the builder replace the o-rings.
Mar 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Plastic melted on burner- how to remove?
If you can break away the plastic then you will be fine, but never use a scraper on them. If all fails replace.
Feb 15, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Burner fails to ignite
I have this cooktop and it is hands-down the worst. That clicking sound is the spark missing the mark because of a crack or chip in the ceramic igniter. Damage is caused by the ceramic heating too quickly. Especially when the house is cooler in winter, or in air conditioning. I had a Jenn Air repair guy in to replace them before the warranty ran out and he said this happens with every single one of these models with the ceramic igniter. Also, one of the knobs on the front by the medium burner got so hot it melted. He gave us a new one. He had a whole box of them in his truck! He told us the design was inferior and that Jenn Air uses a different igniter for higher end models because of this problem, but won't re-engineer the lower end units because it's cost prohibitive. Even with the repairs they cover for the first year, they recoup in charging for service the second year, than profit on the repair and/or replacement charges for the parts every year after that. All the parts sold are OEM--no after markets, so, at roughly $27 a pop for each igniter, they make out pretty good. Oh, and the burner knob is melted again. What a bunch of scamsters. I will never give them my money again and am shopping for a new cooktop. I left a good review at bizrate for this cooktop.
May 18, 2007 | Jenn-Air JGC8536 Gas Cooktop
Bialetti 20-9 Stove Top Espresso Machine Logo
150 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Bill Boyd
carlos parada
carlos parada
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
