Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
Keeps shutting off on its own
I have a iMT620 and when using with my 3rd generation iPOD Touch it shuts itself off. I turn it back on and it plays a few minutes and shuts off again. Note - it did not do this with my former first generation iPOD
I can tell you that it also cuts turns off when plugged into my macbook pro. Very frustratiing when trying to edit in FCE. Anyone talk to Altec about it?
Posted on Sep 28, 2011
I am having the same problem. It appears to happen more on low volume does that happen to you as well? I just called Altec Lansing. Mine may be under warranty still.
Altec said it may be the pins are bent slightly. Not sure i agree. One way to test is to hook up via the auxillary port and see if it still cuts out.
Posted on Jan 11, 2011
Need instant download and installation of ios 7 for iPod touch 3rd gen
The iPod Touch 3rd generation does not support iOS 7. You cannot upgrade to iOS 7 from your 3rd Generation iPod Touch
Sep 14, 2014 | Apple iPod touch 3rd Generation MC086LL/A...
What generation this iPod is serial number 1A009QC075J
iPods come in a variety of generations and models, including the nano, Classic and Touch. Depending on your model you may be able to record video, play games or watch television.
If you're unsure of your device's model, you can determine which iPod you have by using your serial number.
After determining your model, you can find out which features and capabilities your iPod has.
Go to Apple's official website (see Link Below) and click the Support tab.
http://www.apple.com/
Click the Online Service Assistant link, which is located in the Support Services menu on the right side of the screen.
The Service and Repair page will open.
Find your iPod's serial number.
This is engraved somewhere on the back of your iPod, either on the body of the device or on the clip.
You can also find it in your iPod's About screen by clicking Settings and selecting About (or General followed by About on an iPod Touch).
Enter your iPod's serial number and click the "Continue" button.
Your iPod model and generation will be displayed at the top of the screen.
http://support.apple.com/kb/HT1353
also
With each new generation of the iPod Touch, you get new features and updates to the older generation.
The 2nd and 3rd generation iPod Touches are very similar in physical appearance.
The easiest way to determine what generation of iPod Touch you have is to check the model number on the back of the device.
The 2nd and 3rd generation iPod Touches were given unique model numbers to help distinguish your device generation.
Remove any protective case from the iPod Touch so you can see the back of the device.
Locate the model number at the bottom of the back of the device.
Check the model number against the following model numbers.
Third generation iPod Touches are model number "A1318." Second generation iPod Touches are model number "A1288."
Identifying iPod models
http://support.apple.com/kb/ht1353
Aug 10, 2013 | Apple iPod touch
The slide bar will not slide to unlock on my ipod touch 2nd generation. I've tried restarting. It holds a charge and I can play it on my docking station. I can't use it by itself.
I had the same problem with my iPod touch 3rd Generation, the slide bar will not slide to unlock. I could however use the slide to power off at the top of the screen. I tried everything from rebooting it to a full restore and nothing worked. I finally took the Touch Screen Glass Digitizer off and the ribbon cable that connects to the board had come loose. I pluged it back in and everything worked again.
Aug 01, 2011 | Apple iPod touch Second Gen (8 GB,...
I own an ipod touch 8 gig 3rd generation when I plug it into my car sterio auxiliary the speakers only play at half power because the speaker on my touch still plays,I checked that the equalizer on my...
It sounds like you're having a serious hardware/software issue. Have you done a restore? Try that, then if its still under warranty contact Apple for repair. If you iPod is out of warranty check out WhiteBoxService.com, they fix ipods quickly and inexpensively when they are out of warranty.
Jun 17, 2010 | Apple iPod touch
Ipod touch randomly shuts down
Hello. This is actually a very common problem with the 1st Generation 16GB Touch. It is recommended you do a system restore before these steps, but not necessary.
Step 1.
Go into Settings, and click on the General Tab
Step 2.
Set Auto-Lock to Never
This should keep it from shutting down randomly. If this does not help the problem then it is an issue with hardware.
Mar 24, 2009 | Apple iPod touch
My ipod nano third generation won't work.
try resetting your ipod by sliding the "hold' thingy back and forth once, then pressing Menu and Select at the same time(it may take a few seconds, but then the Apple logo will show up, and it should be back to normal). I hope this helps!
Mar 08, 2009 | Apple iPod nano 3rd Generation
Ipod nano 8GB 3rd generation FROZEN!
You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
Aug 09, 2008 | Apple IPod nano Second Generation MP3...
Ipod second generation
just wait for it to shut down ipods sometimes freeze up
May 05, 2008 | Apple iPod nano 3rd Generation
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
1,256 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
