Question about Whirlpool LER4634J Electric Dryer
Dryer stopped turning
Put a load of towels in and the dryer quit turning.
  • 5,911 Answers
If the dryer still heats, but the drum does not turn, this is commonly the symptom of a broken dryer belt.
If the model number is correct, installing a new dryer belt for this dryer involves the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel. NOTE: You should be able to see the dryer belt tightly wrapped around the drum. If the belt isn't present, its a good sign that it has snapped and may be laying in the bottom of the cabinet.
3. Unplug the door switch conector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Roper and refer to diagram H.
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Jul 10, 2010
Dryer stopped turning, belt is not broken
Posted on Oct 11, 2010
The drum on my Maytag dyer model MDE308DAYW, will not turn with a heavy load why?
Because of one of the following
The belt has stretched (new belt)
The belt is slipping (new belt and clean drum)
The Spring on the idler pulley tensioner is weak. (Replace spring and lubricate pulley)
Dec 08, 2015 | Dryers
Lg tromm dryer
You need to replace the bell, also check those roller underneath of the drum are freely turn. It is quite hard to take off the front door of LG dryer, if you not a handy person, call for service. If you want to try let me know, I will guide you to open it.
Oct 16, 2013 | Dryers
Dryer is dead .does nothing
Try turning off the power at the main house breaker, then turn it back on. If nothing happens you probably blew a fuse in the control panel.
Jan 20, 2013 | Roper Dryers
I have aa frigidaire front load washer model LTF2940FE1. We put a pretty big load of towels in this morning. halfway through the cycle the machune made a couple of loud noises, like it was shaking, and...
Never put a large load of anything in, they're quite frankly not designed to work like that for a number of reasons. If the drum is full then water can't circulate properly and your clothes won't get washed as well as they could do.
The machine shut down to prevent damage to itself, try turning it off at the mains for 30 mins, turning it back on and then putting half the load in. This should reset it and stop the shaking.
Jun 24, 2012 | Frigidaire ATF6000ES Front Load Washer
The drum stopped spinning when it was drying a load of towels and will not start again.
I had the exact same thing happen. I was drying a heavy load of towels and jeans and it just quit. No tumbling, no heat, no air.
I took my dryer apart and found that there's a thermo switch on the duct between the fan and exhaust. When open, this cuts power to the motor (which I think also cuts power to the heater).
This is the part: http://www.appliancepartspros.com/part_details.aspx?part_id=4045367
I made a temporary jumper past this and it started. So, I have a new switch on order.
Jan 04, 2011 | Amana NED7200TW Electric Dryer
Smelly clothes after washing
yes musty is actually cooked soap
from the dryer
take a clean just washed towel and put it in the washer alone with no soap
turn on the machine and watch what happens you will see the suds start to form
with this unit, if your using too much soap it will be spun into the cloths and then cooked in the dryer
do one towel load without soap then cut you soap usage way back
anything more than a tablespoon is way to much
remember you bought this unit to save water
1/6 the water 1/6 the soap
and he should be less
Oct 24, 2009 | Maytag MAH2400A Front Load Washer
Dryer stopped running after 10 minutes
Take off the back, there will be a oblong fuse, it has two little wires, replace it.
Jul 14, 2009 | Dryers
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
387 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
