Question about Sanyo DVD-SL20 DVD Player
I have DVD player connected to LG 20LC1R LCD TV. All of a sudden the picture changes to B/W. I do not know how to change display back to colour. I have tried all the buttons on DVD's and TV's remotes. Switching all off/on does not help either. Regards, Coenraad Raath.
  • 4,102 Answers
Hi the first thing you need to do is switch the dvd off at the mains then remove the cable out of the dvd that goes to the telly and also take it out of the back of the telly then refit making sure its pushed in the dvd and telly far enough, doing this will usually solve the problem as most of the time its just static build up.
so once you have refitted the lead plug the dvd back in and switch the telly on then switch the dvd on if the telly goes strait onto the dvd channel then check is working with color if the dvd comes on but dont go to correct channel then you need to press the button on tv remote should be something like av or source or input you will know what im going on about anyway.
so give that a try and see if you have any color then, also check your tv has color on normal telly channels, i take it you have all ready done this as you would have said if everything was affected by this.
if the telly goes onto the dvd by itself and you still have no color then try pressing the av or source or input button on remote just to make sure you are on correct channel, if after doing this you still have no color then try plugging the dvd into another input on the telly doing this will tell you if the input you are using has a fault on it or if the dvd has the fault.
let me know what happens after you have tried the above
Posted on Jul 10, 2010
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Why has my LG tv suddenly gone dark
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 07, 2014 | LG 37LH3000 37" HDTV LCD TV
LG LCD 42' lost colour and now playing on black and white ,please help
http://www.lg.com/uk/support-product/lg-42LC2D#
Here is the link to a free download of the manual. Make sure all of your cables are correctly inserted and if all else fails, try a factory reset as described in the manual.
Jul 21, 2014 | LG 42LC2D 42 in. LCD HDTV
I pressed " setup" on
unplug the power from the TV and the DVD. Plug them back in and try. There is nothing in the tv menu that would knock out your picture, but the dvd player menu has a couple things that would. If unplug doesn't work, tell us what brand dvd player you have.
Feb 25, 2011 | Televison & Video
Video to lcd connection
make sure your dvd player doesnt have a switch onthe back saying something like component or svideo/composite output.. if there is a switch try changing it. if not. you may have to change settings in the players menu. most remotes have a menu button on it. you will want to make sure component mode is enabled/switched
Sep 23, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
Denon dvd 1400
Need to know what kind of video cable are you connected from the dvd player to your TV?
solutiondoct
Sep 05, 2008 | Denon DVD-1400 DVD Player
Sanyo DVD Home Theater System DC-TS760
Change the TV.
I had same problem since 3 years after moving from dubai to bucharest i believed that my home theater was damaged during transportation. I tryed all repair shops in my area but no luck, so i used it as a simple mp3 player at home.
Last week, after 3 years, i changed my old CRT tv with an LG LS3000 lcd tv and SURPRISE...my dvd have colours again.
Jan 09, 2008 | Sanyo DVW-5000 DVD Player/VCR
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Sanyo DVD-SL20 DVD Player Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
