Question about Lutron Electronic Low-Voltage Multi-Location Dimmer by Electronics, Inc
There is no power to this dimmer and led on the left to it stays off.
My led lights start to strobe when I turn on exterior light that is fed from the same line circuit. Solution?
There are two things coming into play here; the lamps and the dimmer(s).
First; LED and CFL type lamps that are to be used on a dimmer switch - must be identified for that use. Looks for the word dimmable on the packaging or bulb itself. These lamps are generally a little more expensive than their non-dimmable counterparts. If it does not indicate it is dimmable, then it isn't - and should not be installed on a circuit controlled by a dimmer switch.
Second; a dimmer switch that will be used to control LED and CFL bulbs (that are identified for use with a dimmer) must also be identified for use with dimmable LED and CFL bulbs. Again, these dimmer switches will be identified for this use and will cost more than those that work with standard filament type bulbs.
Lutron has dimmers for your circuit called a "C•L™ Dimmer" and supports Incandescent / Halogen, Dimmable Compact Fluorescent (CFL) and Dimmable Light Emitting Diodes (LED) type lamps. have a look here:
Lutron Maestro Dimmer and Switch Models
Also, be wary of the total load (wattage) of the lamps being controlled. If you have multiple dimmers in the same box, derating of the switch's wattage capacity (due to increased heat) will be required.
Dec 03, 2015 | Maestro Electrical Supplies
I have 2 led transforms connected to a toggle switch. Can I put a toggle dimmer 600W controlling these transforms?
That depends on several things. Some LED power supplies are not dimmable, and will flash instead of dim properly when used with a dimmer. Many will work just fine. There are also specialty dimmers that are designed to work with transformers, though I've not found them much different.
Oct 30, 2015 | Electrical Supplies
Why does leds hesitate coming on with lutron dimmer
Often led s hesitate even with single pole switch. It's probably not the dimmer. Led s get powered from a transformer inside the fixture and it just takes a second for them to get going. I've found its not consistant. The same two recessed lights have different start up times.
Feb 19, 2015 | Lutron Electrical Supplies
Cooper 9534SG-K master dimmer amber LED goes out when lightsbturned off
Any switch with a light in it needs power to the switch along with neutral
May 07, 2014 | Cooper Wiring Devices Aspire Smart Dimmer...
My master dimer and companion dimer led lights went out and I can't turn the light fixture off. The light stays on but the switch does nothing. Do both switches need to be replaced or just one and how do I...
If you can't turn them off, then chances are that the dimming element within the master dimmer shorted. Some dimmers can get triggered by a hellacious bulb blow-out where a surge of current will ruin the semiconductors in the dimmer and, basically, short it out. If that's the case, I can't guarantee that nothing was broken in the companion, but zero dimming capability usually means the master dimmer.
Also, because its shorted, there's not voltage left around for the dimmer's to use to power up themselves - that's probably why the LEDs on neither device are turned on anymore. Replacing the dimmer should fix that.
Jan 09, 2011 | Cooper Wiring Devices Aspire Smart Dimmer...
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
My laptop won't power up. I have removed the battery and tried starting it, nothing. I removed the AC source and tried with only the battery and nothing. I noticed the led is a little dimmer than normal...
I know this sounds simple but have you checked the power connections at the brick (middle of the power cord) often this comes loose and is not noticed until battery is dead. The leds staying dim is what made me think of this. They will go out when on battery only especially if power cord is not producing any power. When you plug in the laptop do you see a little battery charging light come on?
Jun 16, 2010 | Dell Latitude 110L Notebook
Lutron Electronic Low-Voltage Multi-Location Dimmer by  Electronics, Inc Logo
64 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
Craig Butler
Craig Butler
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
