Question about HP Officejet 5610 All-In-One InkJet Printer
Scanner faild my problem with the scanner when i hit to scan a paper (make a copy) it goes slowly it take 30 min & the scanner stack in the middle
I dont know how to operate scanner to scan?
Posted on Feb 02, 2009
I can't seem to get my scanner to work, please help me
Posted on May 06, 2008
Need user manual and software for a HP ScanJet 4p scanner
HI...................
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
  • LINK OF THE USER MANUAL IS GIVEN BELOW.............
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=25293&prodTypeId=15179&objectID=bps01187
  • LINK OF THE DRIVER IS GIVEN BELOW................
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=25293
Sep 23, 2011 | HP Office Equipment & Supplies
How do i get my scanner to operate - I put a piece of paper on the glass - hit the scan button - then nothing happens - the printer says " PC scan standby" . What do I do next ? Do i need to...
1. Install the MP Navigator EXsoftware located on the disc that came with the printer.
2. Go to Start > Programs > Canon Utilities > MP Navigator EX > MP Navigator EX.
3. Select Photos/Documents or Stack of Documents.
4. If Photos/Documents was selected, open the top of the scanner and place the document you wish to scan on the glass with the top facing to the left. If Stack of Documents was selected, flip the plastic tray open on the top of the printer and place the stack of papers in the tray.
5. Select the Document Type in the left pane, then click the Scan button.
6. The scanning process should start. When it's finished, select Save to save the document(s) as a JPEG, or select Save as PDF to save it in PDF format.
Jul 07, 2011 | Canon PIXMA MX340 Wireless Office...
How do you scan an image onto the computer using the Canon MP190 series? Ive tried hitting scan and it only tried to copy the image and print onto paper.
Place the paper you wish to scan on top of scanner.
1. Go to window start manu.
2. Find picture board.
3. Click the file manu at picture board, and find the scanner.
4. Click the scanner and it will scan the paper as soon as you click ok...
5. After completion of scan, click "save as" and name the title wish to make.
That's all...
Apr 21, 2011 | Canon PIXMA MP190 All-In-One InkJet...
HOW TO ALIGN SCAN IN A PAPER WHEN COPING
Two ways
1-just lay the paper on top facing up and hit copy and it will feed in to the rollers and print
2-open the scanner, and lay paper face down using the built in marker, "edge", and close lid hit scan
May 17, 2010 | Lexmark X2500 All-In-One Printer
Printer doesn't copy
indicates that the page on the scanner is upside down
the printed side faces down
Oct 26, 2017 | HP Photosmart C4180 All-In-One InkJet...
CB92XLT hand held scanner keeps hissing and won't scan
Got the same issue man, you fix it? im checking mine over now, will let you know if i fix it. if you still need it.
Feb 14, 2009 | Uniden BC92XLT Handheld Scanner
System Error [L1-00]
Error code L1-00 indicates that the scanner is locked down for transport. There is a dial under the scanner by the paper output tray. Rotate the dial, and the error message may be cleared. The dial controls the scanner lockdown mechanism.
Feb 25, 2008 | Sharp AL-1655CS Laser Printer
Scanning does not stops
please check all sensor arms in the document feeder. The sensor arm in the middle just below the separation pad is called 'paper end sensor'. If this sensor arm is blocked or broken the scanner don't stop the feeder.
Another possibility is a driver error.
Jan 08, 2008 | Fujitsu M4097D IPC Path-Through Flatbed...
Stucked samsung
Are you saying that when physically looking at the scanner light bar, that the light bar is cocked at an angle? Where exactly is it stuck? left side, middle, right side of the glass (when facing the unit)? ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
60 people viewed this question
Ben Johnson
