Question about Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent
Tankless water heater
Nothing will get this heater to come on - continue to get er code
    Novelist:
    Champion:
  • 230 Answers
What error code do you get? I listed the Bosh telephone number below. They should be able to walk through it with you and diagnose it. Be prepared for long hold times though. I also listed the web site. There you can download the manuals and such. Good luck.
1-800-642-3111
http://www.boschhotwater.com/
Posted on Jun 17, 2008
I have a Richmond tankless water heater and it has L1 error code...can somebody help me with this?
Might be able to help. Except L1 does not show on any error code file.
Copy following link for Rheem Richmond Ecosense etc computer water heater troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Are you sure the error is not IL? Delime tankless.
Or UL flashes and indicates reset.
Or CL flashes and indicates fault history is cleared.
Or error 11 combustion failure? Call for service.
Or P1? Low water pressure, clean water filter check for leaks and crossover caused by bad single-handled faucet cartridge.
I recommend calling Rheem to find local technician who is qualified to work on tankless computers. Tankless are not ordinary water heaters, and they require continual maintenance to avoid common error codes, especially as unit gets 2-3 years old, after warranty has expired.
The required maintenance and expense of repairs, and general fact that people cannot make their own repairs, make tankless computers a bad choice for heating water.
If unit is 4-5 years old, it might be best to install tank-type heater for $385 from Lowes and cut losses.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 08, 2013 | Rheem Richmond Encore Tankless Nat Gas...
Manual
Copy following link for Rheem tankless troubleshoot resources, including error codes, manuals, and general information for maintaining your tankless computer that heats water.
Multiple error codes can indicate failed PC board. Rheem will send PC board... so your computer-that-heats-water might have failed motherboard.
Continual maintenance can help avoid common error codes, but some problems are insoluble and chronic.
Jul 16, 2013 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem Pronto water heater Error code E1
Before calling service technician, open following link for troubleshoot resources include Rheem chat, error codes, and regular maintenance manual, and possible product manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Clean the water filter as shown in product manual.
Error E1 is not specifically shown for Rheem/Pronto tankless.
1 is usually related to water flow.
E errors are related to temperature, so E1 can be temperature sensor failure on hot water pipe.
E errors can be loose/bad wiring or part failure.
Error codes are considered start-point for troubleshoot.
Each tankless manual recommends cleaning the water filter monthly, deliming heat exchanger yearly, and cleaning combustion chamber and burner parts yearly.
Regular maintenance can prevent most common error codes, but the cost and nuisance will outweigh expected $1-8 monthly savings on gas bill.
The requirement for continual maintenance should signal folks that tankless are not effortless hot water as described in tankless promotion.
Solve most tankless problems same day, yourself, any brand, using minimal tools for about $350.
Oct 02, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
Sep 14, 2011 | Rheem Tankless Hot Water Heater...
No hot water at all when I turn on the hot water faucets nothing nomad I would hear the burner kick on but nothing what so ever
Before calling service tech, open following links for Bosch troubleshoot resources including phone support, error codes, possible manual.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
No error code can mean PC board failure, or plumbing problem
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Aug 13, 2011 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Code 73 on a noritz tankless propane water heater
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
Apr 08, 2011 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
When taking a shower the hot water turns off. When I go to the tankless water heater it says C4 76. What does this mean?
Before calling service technician, open following link for Rheem troubleshoot resources including error codes and typical manuals.
C7 76 is problem with remote control. Following link might help.
Read manual cover-to-cover to make sure your tankless water heater receives yearly maintenance required for unit to continue working.
Tankless are maintenance heavy which can quickly eliminate any promised energy savings unless you de-lime and troubleshoot and read tips-and-tricks others have written and glean information from service technician who visits your house. Mostly glean how much tankless repairs and parts cost vrs buying whole new tank-type gas water heater at local box store, since all costs are energy.
Feb 18, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Unit shuts off when in use, code C7, 76
Feb 17, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
RTG 74-PVN-2 Rheem tankless water heater. Works fine for a month or so at a time, then I get C2 - 13 error code. Did I hear this model was recalled?
Recall website:
http://www.tankless-recall.com/tanklessSearch.aspx
Error code C2 13 call Rheem.
Feb 16, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Terminator Aquastar 125FX Tankless Water Heater: FX Hood Horizontal Vent Logo
88 people viewed this question
Top Terminator Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Terminator Kitchen Range Expert? Answer questions, earn points and help others
