Question about Canon PIXMA MP600 all-In-One InkJet Printer
My Canon MP600 printer won't turn on power source is ok
tutopian
  • 57 Answers
SOURCE: MP600 canon printer computer cannot recognise USB device
Try different USB ports on the computer to see if its a porblem with the port connection and if there's no change there then try using another USB cable that you know is working perfectly fine.
Posted on Nov 28, 2007
  • 41 Answers
SOURCE: my canon MP600 PRINTER
There's a couple things you can try:
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are seated right too
If you STILL have the error code, try these two types of resets:
To clear the memory:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Good Luck!
Maggie B
Posted on Feb 23, 2008
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Posted on Feb 08, 2009
SOURCE: Printer Canon MP600 turned Japanese!
Do what is said above, but you need to press the down arrow button FIVE times - or rather it is the sixth setting in the menu.
The fourth setting says "PictBridge" then something in Japanese. TWO down from that setting is language. Then choose English.
Phew! That was annoying.
Posted on Mar 05, 2009
  • 739 Answers
SOURCE: Canon MP600 printer. Black Ink cartridge PGBK5 is
You need both. One is pigment and the other is dye. One is used for photographs and the other for non-photographs - but it's the printer that decides which one to use.
All Canon printers (to my knowledge) will stop working if any one ink cartridge is empty. This is to prevent damage to the print nozzles. The ink itself is the cooling medium for the hot nozzles.
Posted on Nov 29, 2009
Testimonial: "Instant answer so I can stop trawling the internet now! Thanks"
Canon MP600 printer not printing correctly
The cleaning sponges are on a spingy pad, which can get stuck because of the old ink get a bit gunky. This can cause error 5101.
Try this...
Open the bonnet, use a torch, gently tug the ink carriage to the left of the rails.
Clear any paper jammed in the right of the ink carriage.
Lightly press the cleaning sponges down, (I used a long pen)
Restart the printer.
Jan 12, 2012 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MX700 Won't turn on
Hi there :Did you already tried another power cable ?also tried another power source ? Try also another device on the same power source.I hope this information
will help you.
Dec 05, 2011 | Canon PIXMA MX700 All-In-One InkJet...
"canon mp600..it's about 4 or 5 years old. It
The Power Supplies for the MP600 burn out over time. They are easy to buy and replace:
My MP600 Power supply died as well. Web searches (including Canon) turned up nothing. Called Canon. To order power supply from Canon, call: 866-481-2569 (credit card over the phone, no on-line interface). $34.49 with tax and delivery.
Note: the power supply has black tabs the you push away from the grey power supply case. One tab in front and one in back. The grey power supply box pulls right out of the printer. The internal connector (six colored wires) pulls straight out (there is no release tab/catch). Use small screwdriver or needle nose plyers to carefully remove. Pull/pry the female white nylon connector. Do not pull on the wires.
Jul 13, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Rjwylie@wowway.com..... I asked for assistance regarding fixing my pixma 600 printer. I mentioned that I checked the outlet and the power cord {with a meter}. They are O.K. Do you have any other...
It appears that your MP600 Power supply has died.
Feb 11, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Cannon MP600 printer shut itself down during printing operation . Pressing ON/OFF button will not turn it. I checked connections and power source. Still, no reaction.
Re: "Cannon MP600 printer shut itself down during printing operation ."
If a Canon inkjet printer is turning itself off, then problem is either control board or power unit. When this happens printer is often considered beyond repair, and in any case it must be tested by a technician to find out the problem.Repair involves testing volts out from power unit and testing components on main board.
Considering that the MP600 is quite an expensive inkjet, I suggest contacting Canon support and asking a quote on repair.
Here Canon support pages:
Canon U.S.A. : Contact Us
Canon U.S.A. : Support
Canon UK - Support
Canon South Africa - Support
Aug 30, 2010 | Canon Office Equipment & Supplies
How do you scan 120 negs?
The MP600 cannot scan film or slides. Film/slide scanners need a light source to shine through the film to the scanner sensor. You can use a flat bed scanner with a light source such as the CanoScan 5600F, or a multifunction unit equipped with a backlight source such as the Canon PIXMA MP810, MP970 or MP980.
May 19, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 all-in-one printer.Out of paper?
Try this:
Go into the driver toolbox under printing preferences and select auto
continuous feed from the paper source dropdown box.
Both trays should be of the same size paper and type for this to work.
Jul 10, 2009 | Canon Pixma MP500 All-In-One InkJet...
My Canon MP600 will not turn on after a power failure last night. I've tried various outlets that i know work.
1. change the power cord..
2. in many cases of power failure.. a small ic or chip gets failed in power section of the printer,i recommend you to take your printer to the nearest service centre of Canon.. they will help you out.
Jun 22, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
1,898 people viewed this question
old marine
old marine
