Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My fuse keeps blowing when i plug the tv in. It was working fine and then just blew a fuse. Now every time i put in a new one, it blows instantly when plugged in.
  • RCA Master
  • 8,617 Answers
That could be caused by either the AC main filter board ( Most Likliest) or also the deflection board. You can get replacement boards from www.tvrepairworld.com and free assistance to help determine which board has the issue.
Posted on Jul 10, 2010
Why does the fuse keep blowing on my cub cadet ltx 1050
A fuse blows because the circuit it provide power to has a shorted component or wire.
May 16, 2017 | Cars & Trucks
1998 plymouth breeze hazard flasher fuse keeps blowing
check the hazard switch pull the switch and put a volt meter on the connections with wiring connected to switch if it don't respond or just gives you a L.O your switch is bad and shorting out could happen just from being used a lot or something internal broke switch for that shouldn't be all but 50$ or just go to a parts/scrap yard
Jan 22, 2014 | 1998 Plymouth Breeze
My aquabot keeps blowing fuses in or out of water
may be waterlogged. internal seal failed and its shorting out..
Aug 06, 2012 | Pool & Spa
Radio windows and sun roof fuse keeps blowing
Chafed wiring is my suspicion. The door wiring is a prime culprit, where the harness leaves the car body and enters the door.
Get a blown fuse, wire a 12v 21watt lamp across it and plug it in. The light will go out or flicker as you find the faulty wiring.
Jan 24, 2018 | 2004 Ford Explorer
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Every fuse blows that I put in
Okay, it's not the fuse. It drawing to much current and that's the trouble. You better call the repairman.
Feb 18, 2009 | Symphonic ST419E TV
4X4 KEEPS BLOWING FUSES
follow the wires from the switch on the transfercase,to the plugs on the front end,watch for bad wires
Jan 28, 2009 | 1991 Chevrolet C/K 2500
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
188 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
