Question about Roxio Easy Media Creator 9 Suite (227100) Full Version for PC
Missing modules On starting a number of aps, I am getting a messing to install RecordNow 9 Music Lab Premier.mis. Where do I found this module? I have a Dell Dimension E510.
  • 4,737 Answers
You might have deleted some components of the RecordNow 9 Premier Software
[if i am right, it's ".msi" not ".mis"].
Your only solution is to Reinstall/Repair the program. [I hope you still have the copy, otherwise you'll need to purchase another copy] Open the "RecordNow..... " Setup file and install it directly, if you get any error message, you better uninstall it from the Add/Remove Programs or using uninstaller program. After it's uninstalled, restart your computer and again reinstall it.
If you have any problem, let me know, I'll help you fix this.
Good luck.
Thanks for using FixYa.
Posted on Jul 10, 2010
What are the probable causes of DTCs C0300, P0016, and P0344?
What's an SVG?
Scalable Vector Graphics, SVG for short, is an XML-based format for 2D images, allowing them to be viewed both static and interactive. This makes us able to provide you with a fully interactive image full of links to related diagrams and documents straight from the OEM.
Click on any link within the document and you will be able to narrow your focus on a particular component, or view a related portion of a wiring diagram. Even more, these documents are fully zoomable and printable.
Not able to view SVGs? Click here to download the Adobe SVG viewer P0016-CRANKSHAFT / CAMSHAFT TIMING MISALIGNMENT
For a complete wiring diagram Refer to the Wiring Information.
  1. When Monitored: Engine cranking and Engine running
  2. Set Condition: Powertrain Control Module detects an error when the camshaft position is out of phase with the crankshaft position. One Trip Fault. Three good trips to turn off the MIL.
Possible Causes
ERRATIC CAM POSITION SENSOR SIGNAL CAMSHAFT POSITION SENSOR TONE WHEEL/PULSE RING ERRATIC CRANKSHAFT POSITION SENSOR SIGNAL CRANKSHAFT POSITION SENSOR TONE WHEEL/PULSE RING CAMSHAFT POSITION SENSOR CRANKSHAFT POSITION SENSOR
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
1.ACTIVE DTC
WARNING: When the engine is operating, do not stand in direct line with the fan. Do not put your hands near the pulleys, belts or fan. Do not wear loose clothing. Failure to follow these instructions may result in possible serious or fatal injury. 1. With the scan tool clear the DTC(s). 2. Start the engine and run until operating temp is reached. (Closed Loop) 3. If the DTC does not reset it may be necessary to test drive the vehicle.
Does the P0016 return?
Yes
  1. Go To 2
No
  1. Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
  2. Perform the POWERTRAIN VERIFICATION TEST. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure)
2.CHECKING THE CMP SIGNAL WITH A LAB SCOPE
139476.svg?manualid=1988%26oemid=9 139476.svg.png 1. With a lab scope, backprobe the (K44) CMP Signal circuit at the CMP Sensor harness connector. WARNING: When the engine is operating, do not stand in direct line with the fan. Do not put your hands near the pulleys, belts or fan. Do not wear loose clothing. Failure to follow these instructions may result in possible serious or fatal injury. 2. Start the engine. 3. Observe the lab scope screen.
Are there any irregular or missing signals?
Yes
  1. Go To 3
No
  1. Go To 6
3.CMP WIRE HARNESS INSPECTION
1. Turn the ignition off. 2. Visually inspect the related wire harness. Look for any chafed, pierced, pinched, or partially broken wires. 3. Visually inspect the related wire harness connectors. Look for broken, bent, pushed out, or corroded terminals. 4. Make sure the Crankshaft Position Sensor and the Camshaft Position Sensor are properly installed and the mounting bolt(s) are torqued to their proper specification. 5. Refer to any TSBs that may apply.
Were any of the above conditions present?
Yes
  1. Repair as necessary.
No
  1. Go To 4
4.TONE WHEEL/PULSE RING INSPECTION
1. Remove the Camshaft Position Sensor. 2. Inspect the Tone Wheel/Pulse Ring for damage, foreign material, or excessive movement.
Were any problems found?
Yes
  1. Repair or replace the Tone Wheel/Pulse Ring as necessary.
No
  1. Go To 5
5.CAMSHAFT POSITION SENSOR
If there are no possible causes remaining, view repair.
Repair
  1. Replace the Camshaft Position Sensor.
6.ERRATIC CMP SIGNAL
1. Turn the ignition off. 2. Remove the lab scope probe. WARNING: When the engine is operating, do not stand in direct line with the fan. Do not put your hands near the pulleys, belts or fan. Do not wear loose clothing. Failure to follow these instructions may result in possible serious or fatal injury. 3. Ignition on, engine not running. 4. With scan tool, erase DTCs. 5. Start the engine. 6. Gently tap on and wiggle the Cam Position Sensor. 7. Ignition on, engine not running. 8. Inspect the Sensor connector and harness connector, and inspect the PCM connector and harness connector for loose, bent, corroded, or pushed out pins/terminals. 9. Inspect the related wire harness and the splices in the CMP circuit.
Yes
  1. Repair the wiring/connector concerns as needed or replace the Camshaft Position Sensor.
No
  1. Go To 7
7.CHECKING THE CKP SIGNAL WITH A LAB SCOPE
139478.svg?manualid=1988%26oemid=9 139478.svg.png 1. Turn the ignition off. 2. With a lab scope, backprobe the (K24) CKP Signal circuit at the CKP harness connector. WARNING: When the engine is operating, do not stand in direct line with the fan. Do not put your hands near the pulleys, belts or fan. Do not wear loose clothing. Failure to follow these instructions may result in possible serious or fatal injury. 3. Start the engine. 4. Observe the lab scope screen.
Yes
  1. Go To 8
No
  1. Go To 10
8.CKP WIRE HARNESS INSPECTION
Yes
No
  1. Go To 9
9.TONE WHEEL/FLEX PLATE INSPECTION
1. Remove the Crankshaft Position Sensor. 2. Inspect the Tone Wheel/Flex Plate slots for damage, foreign material, or excessive movement.
Yes
  1. Repair or replace the Tone Wheel/Flex Plate as necessary.
No
  1. Replace the Crankshaft Position Sensor.
10.ERRATIC CKP SIGNAL
NOTE: The conditions that set this DTC are not present at this time. The following test may help in identifying the intermittent condition. WARNING: When the engine is operating, do not stand in direct line with the fan. Do not put your hands near the pulleys, belts or fan. Do not wear loose clothing. Failure to follow these instructions may result in possible serious or fatal injury. 1. Start the engine. 2. Gently tap on and wiggle the Crank Position Sensor. 3. Turn the ignition off. 4. Inspect the Sensor connector and harness connector, and inspect the PCM connector and harness connector for loose, bent, corroded, or pushed out pins/terminals. 5. Inspect the related wire harness and the splices in the CKP circuits.
Yes
  1. Repair the wiring/connector concerns as needed or replace the Crankshaft Position Sensor.
No
  1. Test Complete.
Portions of materials contained herein are sourced from Chrysler Corporation.
Copyright 2007 - 2013 Service Repair Solutions, Inc. Print Image
Apr 21, 2016 | 2006 Chrysler PT Cruiser
2008 mercury Milan premier-po356-missing # 6 cylinder no voltage to spark plug coil what controls voltage to coil
Unless yours is different from most, there is an ignition module which can fail in several ways, and is a common failed item. Failed wiring to coil also possible.
Apr 29, 2015 | 2008 Mercury Milan Premier
I need an install and program instructions for a AP data link pats 2 bypass module
try clutchfield.com try have alot and support pages and online chat
Jan 02, 2015 | Ford Cars & Trucks
Is a autocommand model 21921 remote starter compatible with 2007 chevy trailblazer with factory keyless entry
go to IDATALINK.com,you can enter your car specs and buy correct interface module, door locks park lights dome lights and ignition module.i installed audiovox aps 997c remote start alarm with their module works like a champ.VERY INVOLVED INSTALL
Jan 19, 2013 | Design Tech Vehicle Parts & Accessories
Dear Sirs, I bought Roxio Recordnow 9 software, but I can't install the software. It doesn't work, i tried everything. Can you help me? Thank you very much, M. Nijhof
if you have the disk to install it with. put the disk into the cd rom and let it start up. It is a lengthy wait but it should start up by its self follow the on screen directions. I have the item also this is the way it works for me. Michel
Aug 04, 2011 | Roxio RecordNow Music Lab 9: Windows
Symptoms of a bad pick up module on a 1996 GMC K2500 Suburban
What I see the most often is a stalled engine with a loss of spark when driving. Once the engine cools off it will sometimes start and run fine for a short while then do the same thing again. Often, but not always, the pickup up coil or ignition module [both are under the distributor cap] have to heat up quite a bit before they will act up. I replace about 10 ignition modules for every one pickup coil but either one can cause the same identical stalling problem. I keep a few known good modules around as test units so I can just replace a suspected bad module and road test it to see if it works. Another thing that can go wrong in these distributors are the magnets built into the pole piece. A weak or cracked magnet can cause all kinds of odd problems such as stalling when placed in reverse, misfires over 1,000 rpm, etc. Worn bushings in the distributor can also cause problems. As far as a specific test you can do to see which part is failing? I wish there was a relaible one. I've tried using a lab scope and module testers to diganose the culprit but you have to catch the problem as it's happening for those tests to be accurate.
Jun 17, 2010 | 1996 GMC Suburban
How can i get sony record now to make cds copys
You can get form here -
RecordNow® Music Lab
Thanks for using Fixya. Anand kumar
Apr 12, 2010 | Sonic RecordNow! Deluxe 7.3
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
I keep getting a message from Sonic saying, Installation package for the product SONIC DLAcannot be found. Try the installation again using a valid copy of the installation package. It says that ...
Article Details ID Number: 000131CR Products: Easy Media Creator 9
Easy Media Creator 9 Deluxe
Easy Media Creator 9 Trial Version
WinOnCD 9
WinOnCD 9 Trial Version (Not available publicly)
Easy CD & DVD Burning ("Vista Compatible" labeled boxes only)
OS:
Cause: Through a clerical error, a driver is incorrectly being blocked as incompatible with Windows Vista®. If you do not have one of the above applications, you will need to upgrade to a Windows Vista® compatible version of the software. For Dell Customers
The patch is not intended for a customer base other than Dell. If you do not own a Dell system, it is being offered "as is" and to be used at your own risk.
To download and install the Roxio DLA Update:
  1. Click here for the DLA patch. When the file Download window appears, click Run. Note: If a Security Warning window appears, Click Run.
  2. Follow the installer's on-screen instructions.
  3. When prompted to restart your computer, click Yes.
  4. The computer restarts, and the update is complete
Pleae post here again when you have more issues and ill assist you as long as it takes.
Oct 15, 2008 | Computers & Internet
I recently tried to reinstall Roxio RecordNow 9 Music Lab Premier. After reinstalling it I went to click on the icon to open the program when a window popped up and gave the following message: "The...
Just search your computer for any file hidden or not that starts with sarlicense9
I found a sarlicense9.dat, deleted it and now have no more issues.
I hope this helps.
Apr 23, 2008 | Computers & Internet
Roxio Easy Media Creator 9 Suite (227100) Full Version for PC Logo
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
