My ac wires have come loose...do i reattach the white wire to the white wire, the red wire to the red?
  • 407 Answers
If you are talking about the outside condensing unit, then yes. It actually doesn't matter which wires of the two you hook up, they will both operate the same. Hope this helps.
Posted on Jul 11, 2010
Need wire color diagram
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
Brown = AC 3 pahse - phase A
Orange = AC 3 pahse - phase B
Yellow = AC 3 Phase - phase C
shileds: think of current loops
2 cond
clear or red = +
black = -(neg)
3 cond
red = power (24vdc typically for transducers)
clear = + (signal output)
black = - (signal common)
Hope this helps, oh, and any panel I have design and wired this way is easily understaood by 99% of all service and electrical people I have worked with.
Apr 15, 2015 | Cars & Trucks
We have a DX 1900. It fell and wires came loose and the back jarred off. There are two loose blue wires and one white one. Do all 3 go together? If just the blues go together, where does the white
YOU Must contact to Rowenta, for get help via chat or phone. Normally the electrical diagram is not comming with any iron.
However the iron electric coming with 2 wires red +black. and attached to the 2 wires from the iron
God bless you
Sep 23, 2012 | Rowenta DG5030 Iron
Dogs chewed up wiring from house to outside ac don't know what goes where
Wires used in AC for power are of different color like red for (+) black for (-) and green for (N). You can slice the rubber (about half inch) ends of broken wires and then reattach them matching the color, like red to red, black to black and so on. After that apply insulation tape on the joints. Make sure you switch off the power before you do all this work. If you are unsure, please call the AC service center and they will send an electrician to fix this.
May 13, 2011 | Heating & Cooling
Wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Jul 16, 2010 | Heating & Cooling
Electrical cord was accidentally pulled out of ac unit.
Green is ground, secure to frame. White goes to compressor, located behind LED/LCD, lower right corner you'll see a number of other colored wires kind of in a circle, each connected to a 'port'. The black goes behind LED/LCD panel also. Top far right, back corner. 2 ports are connected to a black box..a red one and should b your black one.
GOOD LUCK!
Jul 13, 2010 | Kenmore 75085 Air Conditioner
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
I replaced a clogged drain hose attached to my Aprilaire 600 humidifier. I then discovered no water was being supplied to the humidifier. The problem appeared to be a dangling solenoid wire that I had...
No, you need to attach one of the solenoid wires to the red wire and one to the white wire.
So, undo the wire nut with the three wire and hook one of the red or white wirtes to the wire nut with only one wire. Then you sould have a black wire and one of the other red or white wires under each wire nut.
Problem amy be that you now have burned out the transformer that runs your Humidifier. By hooking the red and white wires together you may have shorted that out and killed it.
If you humidifier does not work after hooking it back uo right then you will need to change the transformer.
Heatman101
Dec 28, 2009 | Aprilaire 600 Humidifier
A/c wiring
The Red/White comes from the AC amplifier into the AC magnet clutch, from termianl 13.
The White/Blue wire goes back from the AC magnet clutch to the AC amplifier, terminal 14
The Black/White wire goes to two places, via a splice splice, 1 is to the relay box, Fan Relay # 3, and 2 is to the AC Magnet Clutch Relay.
Jun 15, 2008 | 1993 Toyota Camry V6
I have a goodman ac, the wires came off from my house i have a red wire and a white wire on the ac there is a yellow wire and a blue wire. does the yellow got to the red?
check against wiring diagram white and red are line current always but I'd check against any diagram you have of the unit
Apr 21, 2008 | Heating & Cooling
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
