Question about GE WSXH208A Front Load Washer
My front loading GE washer WSSH300 will not drain.
    Problem Solver:
  • 12 Answers
Don't know if this will help or not, but your owners manual is available at http://genet.geappliances.com/DocSearch/Dispatcher
Water won’t drain
Drain hose is kinked or •
Straighten drain hose and make sure washer is not improperly connected sitting on it. Top of drain outlet should be less than 8 ft. (2.5 m)
above floor. Household drain may • Check household plumbing. You may need to call be clogged a plumber. Plumbing this washer directly to a pipe is hard on the motor. Usually the drain hose elbow is inserted in a stand pipe, meaning the washer would drain water on the floor is the stand pipe is clogged.
Several items can cause the lack of draining.
If you can get to the drain hose, try lowering to a point that it will drain into a bucket. If it drains the system is not clogged. If you advance the timer and the washer drains this maybe the culprit. The motor can overheat and shut off. I would advance the timer to spin and listen for a hum in the motor and then quiet, a sign that the motor has overheated. If the water drains it sounds like the timer is at fault.
I would first make sure the drain hose is properly installed and not kinked somewhere. In earlier GE's the water drain pump could clog, your manual doesn't indicate that as a defect. Regardless timer, motor and pump are in the cycle to empty the washer water.
Posted on Jul 11, 2010
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
Ge wssh300 will not start may, just beeps
hold the start and select button in for about 30 seconds together until you hear a beep; this resets the control panel
Aug 04, 2009 | General Electric WSSH300G Front Load...
GE WSSH300 stops after wash and need to hit start again to finish
Be sure to rule out one of the simplest things first---be sure the button that gets depressed when you close the lid is still functioning (or even THERE) Sometimes, if you have had a severly offset load, this switch can become damaged. Some washers will not continue to advance if it " thinks" the door is opened.
May 09, 2009 | General Electric WSSH300G Front Load...
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
GE washer WSSH300
Shut water off at faucet's pull out washer disconnect hoses from back of washer at water valve look in valve to see if it is clogged with sand , lime or anything if so clean out. put hose end from washer in bucket turn on faucet to see if you have water there then do same with other hose. if all ok remove water valve check coils with volt/ohm meter if bad replace valve if good check at wires that plug onto coils on water valvefor 110 volts with volt ohm meter if uncomfortable with doing any of this Call Repairman ..
Jan 10, 2009 | GE WSXH208A Front Load Washer
How to secure front loading drum for moving????
transit bolts vary with machine. pack polystyrene blocks tighty between tub and cabinet and that will do the trick
Sep 25, 2008 | GE WCVH6260F Front Load Washer
GE WSSH300G0WW front load washer
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
Sep 15, 2007 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
714 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
