How to print on both side of the paper on a hp officejet 6200
    President:
  • 2,712 Answers
Hello cambutter,
When you give the print command, it should open up the print properties box. Here click the 'properties' button and choose the 'printing shortcuts' tab. (should automatically open to that tab). At the bottom right of the box, (the last option), it says 'print both sides'.
Choose your setting here and print away!
Note: Depending on your software, you may get a different print box, and if you see "collate" here, then simply check that.
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 19, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Apr 23, 2008
    Has your issue been resolved? If you have, please close this
    problem ticket with a Helpful or FixYa! rating. I would be very grateful for
    your gesture of appreciation.
    post them here.
    Cheers!
    IrishDruid
    "Discover
    How to Achieve Your WILDEST DREAMS"...
    Free Download
    FREE SOFTWARE GIVEAWAY
    Windows Utilities
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
Two sided copies
that machine does not have an automatic duplexing capability
what you have to do to print both sides of the paper is in the print selection highlight print pages 1,3,5 etc and when finished turn the pages upside down and in backwards , the print pages 2,4,6,8
in the pages selection -print odd pages then when done print even numbers
Jun 17, 2017 | HP Officejet 6200 All-In-One InkJet...
I can't figure out how to get the 2-sided printing to work on my HP OfficeJet 6110.
your printer can only manually print on two sides, reload the paper to do so.
May 16, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My fax machine stays on and I can't print somethings. Everytime I try to print something the "FAX" machine window opens up....instead of the "PRINT" window. I clicked on the little arrow by the printer...
Try this.. Go to start, devices and printers and you will have a few things listed in there that are related to your printer. Most likely it will say document writer, fax and your hp printer. Make sure that the check mark is on your printer, not your fax. This indicates what your default printer is. To change this, right click on your hp printer and select set as default printer. Once this is set try printing again. Let me know if this works, if not we will try step 2. Hope this helps!
Oct 23, 2010 | HP Office Equipment & Supplies
My hp officejet 6210 all in one is instaled under general heading: officejet 6200 series. Result: the printer reacts to command given by laptop windows xp but does not print given text. The paper comes out...
Are you able to print Self test page from printer ( standalone ) or able to make a copy ? if you are able to make copy/print self test page from printer, this issue is with Printer Drivers, You can uninstall and reinstall the software ( download the latest software and drivers from HP website )
If you are not able to make copy/print self test page from printer, it is issue with printer/cartridges... you need to re-align the printer
to clean/align cartridge
On Printer Front panel
Press - Setup Button ( press ok)
Press - Tools ( Press Ok )
Press - Clean Cartridges ( Press OK )
And/Or
Press - Align Cartridges ( Press OK )
Jun 22, 2010 | Office Equipment & Supplies
Print cartridge error HP Officejet 6200
May be your printer catridge has been faullty. so pls checked it with another catridge.
Sep 18, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Will not print! was working fine and stopped?
go to start>>control panel>>adminsitrative tools>> services
right click on printer spool and select stop.
restart the printer. restart the printer spool.
May 14, 2009 | HP Officejet 6200 All-In-One InkJet...
My HP Officejet 6200 All-in-one won't print a word document.
When you plug the usb cord from the printer to the laptop, the laptop should have something to say about it. Usually, 'detected new hardware', new hardware installed and ready to use'. The second message usually takes a little while to show up. Maybe a wizard will pop up, you have to do whatever it wants. If you don't have the install disk it wants, it will have to go online to get the drivers.
Apr 26, 2009 | HP Officejet 6200 All-In-One InkJet...
HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Mar 13, 2009 | HP Officejet 6200 All-In-One InkJet...
I cant print double sided papers on my HP 4850
Right click on the printer
click properties
click advanced
check two sided box
Jan 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
87 people viewed this question
jasbo
jasbo
