Question about Volfenhag ZX-5007 Car Audio Amplifier
Need help setting amp right
I have 2 12s Q powers with a Volfenhag Zx-5007 amp and i need help making it hit perfect.
  • mistavp05 Jul 10, 2010
    Are you looking for big bass or clear and loud music?
    Problem Solver:
  • 5 Answers
Volfenhag's are cheap. you get what you pay for. that is the german equiv. to pyramid or kraco.
Posted on Jul 14, 2010
How to switch protection off (red LED to blue)
The protection light is on indicating a short or over- voltage problem. If you disconnect the speaker leads and the light goes off or green then the problem is a shorted speaker or wiring problem. If the light stays red the problem is inside the amp and it will need service and parts.
May 03, 2010 | Volfenhag ZX-5007 Car Audio Amplifier
Volfenhag 2050 staying on prtection mode
AUDIO OUTPUT ARE DAMAGED, CHECK THE SPEAKERS IF SHORTING, WIRES ARE CROSSED...
Oct 14, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
Volfenhag amp adjustments
Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
Sep 23, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
Need help please...
If you unplugged the fuses, the amp won't come on at all. I'd say its a blown transistor, you can test this by opening up the amp and using a multimeter to check resistance on the transistors.
Aug 03, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Is my amp powerful enuff for woofer
That amp should work fine for that sub, but you should make sure that the amp has a good power system going to it, and the box for your sub is the right one. Either one of those things could cause problems if not done correctly.
-Dynami
Apr 02, 2009 | Volfenhag ZX-4812 Car Subwoofer
Volfenhag ZX-7160 Car Audio Amplifier owners manual to adjust the frequency also wiring diagram diamartn64@gmail.com
its very easy to hook it up. your best bet is to join www.carstereo and ask your question there.but it is easy to set and hook up amp if you really need help email me
Mar 03, 2009 | Volfenhag ZX-7160 Car Audio Amplifier
Protection Light coming on with loud volume and power
It's most likely that the over-current protection is tripping at high power. At lower voltage, the amplifier can't produce as much output power and therefore can't produce enough current to trip the protection circuit.
You need to check your speakers to make sure that they are not shorted. With an ohm meter, the resistance across the voice coil shouldn't read any less than ~90% of the rated impedance.
If the speakers and the wiring are OK, the amp may have an internal fault causing the amp to go into protection.
Let me know if you have any other questions.
Aug 13, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
I can only get one speaker to work
Is ur unit brand new? if thats brand new ofcourse 90 percent OK. You identify first the rear and front speakers (left & right). Beware to short circuit the unit. short circuit may cause damage ur power out..Set up first the speakers before you conect the power supply..hope i help you even a little...thanks..
Mar 16, 2008 | Volfenhag ZX-7170 Car Audio Amplifier
Volfenhag ZX-5007 Car Audio Amplifier Logo
101 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
