Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
My Fisher and Paykel DS-603 (integrated) keeps beeping. When I open it, the rinse light is lit. Can anyone help? I'm out of warranty.
  • 10,515 Answers
Disconnect the power supply for few minutes, say 15 minutes and then turn it ON. Do you hear ant beep?
If yes, this is a not a bad news. If you could see any Error Message on the Display, it would help. Unless, more often it is a Faulty Control Board that would cause unnecessary beeping. The cost of the board is around $150 - $200.
Now, here is the deal. If you know, how to read schematics and have appliance repair experience, i could give you the link to purchase cost effective service manual and few pointers unless i would recommend to give a ring to repairman as there needs to be few diagnostics tests to be done before buying non refundable expensive part such as control board.
As i could not diagnose your machine, i could only provide you few pointers.However, all the work needs to be done by you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 10, 2010
  • gowjim Jul 10, 2010
    I tried what you suggested. Seconds after starting up, the dishwasher started beeping again. The rinse light was once again lit up.
  • taran_2005
    taran_2005 Jul 10, 2010
    Thanks for your response!!
    This usually confirms that there is a problem with control board. This is a common problem with most of the dishwashers.
    If you wanted to repair it, let me know and i would be able to tell you few pointers. However, i usually suggest the repairman to do the work. The ball is in your court and you are the one who needs to take a decision.
    Hope i helped you.
    Thanks
My Fisher Paykel washing machine won't spin it's goes to rinse then stops. The wash light and the last rinse light comes on also spin light comes on and it's beeping
Ian,
Which wash light? There are a total of 8 lights in the sequence on the panel. From left to right, can you give me the numbers of the lights that are on. I have a Fisher Paykel fault code manual, so I can look it up if you give me the lights that are lit and also give me the model of your machine, some of the codes are different for different models.
Aug 13, 2015 | Fisher Washing Machines
Beep continuos and cycle stops
Water flood in the base of dishwasher. Check the fault code lights. If F1 then this confirms the problem. Need to find the source of leak.
Mar 14, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
Water will not empty and beeping will not stop on Fisher & Paykel DD6051
The flood switch has turned on. There is a leak into the base of the housing. Turn mains power off. Open bottom drawer and dry the base using towels etc. Need to find the source of leak. Lid seal or hoses.
Sep 14, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher won't *******
Turn mains power off and on after a little time.
Do you get any fault code on the display if you have LCD or if integrated, which lights are on on the drawer door?
Jun 05, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
How to change a element in a Fisher and Paykel Ds 603 dishwasher
these units r very tricky to change the element. it involves pulling the wiring loom, hoses and turning it upside down to make it easier. sorry to ask u this but why r you changing the element? please reply and i can help u more.
Apr 28, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
My 603 integrated keeps stopping mid cycle and beeps (3 x 2 short beeps). this can happen 2-3 times in the same cycle
I had the same problem; it turns out that there is a little plastic clip that holds the main circuit board in place and aligns the sensor on the circuit board with a little hole on the unit. This clip was broken and hence the circuit board was moving around, causing misalignment of the sensor and hence the unit would turn on and off during cycles. This may be your problem.
Dec 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
DS-603 lights keep blinking, won't stay turned on.
Hi. I am unable to help you fix your problem, however I have just had this problem with my dishwasher exactly the same model. I was wondering if you have fixed this problem yet and if you have how.
May 26, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Mar 09, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
50 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
