Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Opc and power light flashing
Switches off by itself and opc and power light flashing
  • 11,361 Answers
That means you may ahve problem in the power supply or the backlight inverter board. You can disconnect the cable to the inverter to see if the 24vdc comes back on, then you need to load it with 24vdc load that can draw 3~4amp to see if the power supply can handle it OK and maintain 24vdc output. Then you need to check the inverter board for shorts ot burnt out parts.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 11, 2010
Sharp Aquos LC46D82U Power & OPC blink together once, then Power twice alone. Where can I find the error codes to fix this?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Sharp Aquos Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 29, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
MY Sharp LC46D62U wont turn on
Power and OPC LED lights flashes?Common on Sharp LCD tv.Tv is still useable.Tv have Tuner signal board problems.Every times Power and OPC LED lights flashes.Just push the remote power button again and wait.Sometimes Power and OPC LED light will flashes require push power again wait again Power and OPC will flashes two or three time push power button and wait.Must do this two or three time before the backlight will light up and tv work.
Jan 07, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Aquos model LC46D64U...approx 2 years old..Won't power up and get the power light flashing 3 times then the OPC light once..which is repeated...Any ideas...I believe this is quite common with Sharp TV's
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Oct 18, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos has the power light and OPC light flasing but nothing works
First turn on power light stable at all?Power and OPC lights well flash,but push on/off power button do this couple times after the Power and OPC flashes well backlight come back on well work.This problem very common is Sharp tv.
Jan 17, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
195 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
