Question about Ariens 21 In Classic Walk Behind Push Lawn Mower ()
Need new muffler can't find part #
Model # 911086 ser# 001264
    President:
  • Ariens Master
  • 1,545 Answers
After much research, it appears you have a 6.5 Briggs & Stratton OHV engine. Find the mufflers part #'s and prices for it here:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=121602-0269-E1&dn=21430006
A guy in South Florida had a used one listed on Ebay for much cheaper. Check to make sure that you actually need a muffler and not an exhaust gasket.
Posted on Jul 10, 2010
I need a muffler for a Jonsered 520 sp
Fixya does not sell replacement mufflers.
Aug 08, 2016 | Garden
Muffler pipe rusted and broke clean in half, but actual muffler is new.
NEED TO TAKE VECHICLE TO MUFFLER SHOP LET THEM FIX RUST PIPE WITH A NEW PIPE.LET MUFFLER SHOP FIX BECAUSE THEY CAN WELD JOINT SEAL BOTH NEW EXHAUST PIPE AND NEW MUFFLER SO YOU WONT GET CARBON MONOXIDE POISON LET MUFFLER SHOP CHECK ALL THE EXHAUST SYSTEM BECAUSE THE WHOLE SYSTEM COULD BE RUSTED DROP DOWN WHILE DRIVING YOU PROBABLY NEED NEW EXHAUST PIPE HANGERS.
Jul 16, 2011 | 1996 Mazda Protege
Mi hyundai accent GLS 2002 tiene el check encendido y tiene los errores p1401 y el p0442, que puede ser y como puedo solucionarlo, ademas la luz del dasch se apaga y se enciende constantemente que puede...
The 2000 model year Accent adopts a different "pressurized" leak check system capable of detecting a 0.020" (0.5 mm) diameter leak (previous Hyundai systems detect a 0.040" [1mm] diameter leak using engine vacuum). The new system uses a Diagnostic Module for Tank Leakage (DM-TL) to close and pressurize the fuel evaporative emissions system. The DM-TL replaces the fuel tank pressure sensor and the canister close valve from previous systems. Other significant changes were made to the system logic, including several new diagnostic trouble codes. It compares the differences between the 2000 model year Accent and previous evaporative emission systems... Que puede ser? Tiene dos opciones. Primero, puede pagar que un tecnico diaga el problema (exactamente) o sigue, secudariamente, su adivnaza.
Jul 11, 2011 | 2002 Hyundai Accent
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Can I change just the muffler on my '02 dodge neon or do I need to change the entire exhaust system?
if exhaust pipes are in good shape-no rust thru than just replace muffler
Mar 29, 2010 | 2002 Dodge Neon
New Furnace Coleman Model 8623A Ser#037873318
Red wire to R. There may be a R, Rc, Rh, You will have either one or 2 of these. They shaould be jumped together with a small jumper from the factory. Then white to W, green to G and yellow to Y
Mar 20, 2010 | Coleman Heating & Cooling
Broken safty guard---need to purchase a new one model EL-7 Ser # 154445 Rimington 16 2.5 HP
Check out master parts, they have remington chainsaw parts, you'll need the model number of your unit ( usually 8 digits long). 800.446.1446 or www.masterparts.net. I hope this helps you!
Feb 25, 2010 | Remington 16" Electric Chain Saw
Where will I find the spark arrestor for the Ryobi RLT30CES and how do I clean it?
Hello dejbutcher:
The Spark Arrestor Screen is in the Muffler. It is Either Attached to the Outside of the Muffler or Inside the Muffler. If Mounted on the Outside, then you can Remove the Bolts Holding the Cover and Simply Remove the Screen and Clean it or Replace it with a New Screen. If it is Inside the Muffler and the Muffler is a Sealed Unit and Does Not Seperate, then a New Muffler is Required. If the Muffler will Seperate, then the Screen can be Cleaned or Replaced just like the Extrernal Spark Arrestor Screen.
You can View a Breakdown of this Unit at this Site Addy; http://www.ryobitools.com/parts and Select "Go to Ryobi Outdoor Parts Store". Now Select "Repair Parts Catalog". Select I Agree to Terms. Now Enter the Model Numbers and Click Search. Now Double Click on you Model in the Results Area.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 14, 2009 | Ryobi Garden
Ariens 21 In Classic Walk Behind Push Lawn Mower () Logo
100 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
