Question about Cyberhome CH-DVD 300 DVD Player
Worked fine one quit the next with a dvd in it how
Worked fine one day quit the next with a dvd in it. It never smelled like it was overheating at all. We have used it probably 5 times total. How do we get the dvd out and is there a reset button or something?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
On the underside, use a key to slide around in the slot that says emergency hole.
Posted on Jul 14, 2010
My washer,a W225LV will work one day and not the next! When it quits you can smell something .....wait a while and it starts to work again! It was bad out of balance, what is wrong!
THE MOTOR WOULD BE MY BEST GUESS WITH OUT LOOKING AT IT BUT IF IT WILL RUN A BIT THEN CUT OFF AND A SMELL IS COMING OUT OF IT THEN CHANCES ARE THE MOTOR IS OVER HEATING AND CUTTING OUT ON OVER LOAD PROTECTION
Nov 02, 2010 | Magic Chef CAV2000 Top Load Washer
I left my Makita 9514b out in the rain one night and I let it dry out the next day in the hot sun. I was using it and everything was fine and all at once it quit working. I figured it was still wet but I...
what does the end of the brushes look like, are they dark or shiny. what I would do if they are dark is unplug tool find a wooded emery board and turning the spindle by hand rub the board on the commutator to reseat the brushes. If this doesn't work let me know and I will try and come up with something else.
Aug 09, 2010 | Makita Angle Grinder
The DVD player on my VCR/DVD player quit working. It was fine a day ago, but now all I get is a blue screen. The VCR works just fine. I've checked all the connections and cannot find a problem.
The problem seems to be the laser lens on the DVD player. If you have a DVD lens cleaner try cleaning it. If that doesn't work then it is Possible that the laser lens is bad.
Dec 05, 2009 | Televison & Video
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
Car overheated one day the fine the next but no
your heat is not working becuase the coolant level is too low meaning your heater core is full of air. the reason your car overheated is because the water pump impeller splines are gone and you need to replace the water pump. it is driven by the timing belt so replace that too. and the tensioner. this is the number one cause of vw overheating, especially on a diesel. i have replaced about 50 water pumps on this engine because of this.
Sep 27, 2009 | 2002 Volkswagen Jetta TDI
Overheating and missing
The first thing to do is quit throwing parts at your car. That said, this is a very generic answer. Missing and overheating that started in a similar timeframe is quite possibly a head gasket issue. More info would be needed such as exactly how does your guage act, does it overheat quickly if you keep the rpms up? Does it smell sweet near the exhaust? Does it Smoke/steam out the exhaust when you first start it? Where any of your spark plugs white on the electrode end? Also a clogged cat. can give you this trouble. At idle everything is fine, at higher rpms the exhaust cant get out fast enought holding in the heat (overheating after a while) and causing a miss just the same as if a exhaust valve was stuck. Two things to think about.
Apr 30, 2009 | 1993 Ford Probe
Thermostat on 2004 Honda Accord not opening, No Heat
is the heater core leaking?can you smell antifreeze?
Feb 26, 2009 | 2004 Honda Accord
Mitsu model #ws-55905 Started losing picture while watching a DVD. The next day it worked fine. Now it lost the picture and sound completly. I have no response at power on, only the green power indicator....
actually something on the main board was getting overheated before due to that it was loosing the picture.and now that component is got totally overheated and blowned/burned out.so its quite necessary to replace that faulty component from the board by checking it with a meter.so its advisable that you do not turn on your tv to avoid further damages till it gets repaired.
Feb 20, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Immediately shuts off when turn on.
get another speaher wire two wires are touching making ti go into protect mode..
Jan 15, 2007 | Onkyo HT510 Receiver
Cyberhome CH-DVD 300 DVD Player Logo
74 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
