Question about Mitsubishi WD-62525 62" Rear Projection HDTV
The green indicator light wont stop flashing - Mitsubishi WD-62525 62" Rear Projection HDTV
  • Mitsubishi Master
  • 8,617 Answers
That can usually be repaired by installing the repair kit called the V26 Chassis DM / Power repair kit. The kit contains the parts and the CD with detailed instructions. Its at www.tvrepairworld.com under the Mitsubishi repair kits.
Posted on Jul 10, 2010
3 Suggested Answers
tvguy171
  • 106 Answers
SOURCE: wont power up , green indactor light wont stop flashing
You have four capacitors bad on the "DM" module in the unit. I recommend you get a tech to do this repair. This is due to the complexity of accessing the DM module. A qualified tech can do this repair in under an hour. You can find a tech in your area by inputting your zip code on the home page of this website. Let me know if I can be of further assistance
Posted on Jan 11, 2009
  • 75 Answers
SOURCE: "timer"flashing green light
should check then capastors on the dm board. they are on a board in a silver case on the left side of the set when looking from the rear. the capstors should have 16v @ 1000u wrote on the side of them and are about 1 inch tall size of a dime round. Dont do anything without unpluging the tv frist from power. Just to let you know I have posted this before.You can use 25v/1000u if you cant find the 16v/1000u. You can higher in voltage and be ok but donot go less than 16v rateing. this is what i would check out frist.
Posted on Jan 02, 2010
When i use the indicators the neutral light or brake light flash in time with indicators what is wrong
it sounds like there is a bad ground (earth) someplace in the vehicle .
Sep 14, 2015 | Cars & Trucks
My Mitsubishi TV WD 73735 has a flashing green light and wont stop is that the bulbs or timer
Your manual's trouble shooting section will tell you what the flashing green is indicative of.
Sep 10, 2015 | Mitsubishi Televison & Video
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    May 04, 2012 | 1994 Nissan Maxima
    When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
    A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
    May 11, 2011 | Panasonic PT-52LCX66 Projection Television
    My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
    the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
    Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
    Wont power up , green indactor light wont stop flashing
    Jan 11, 2009 | Mitsubishi WS-55513 55" Rear Projection...
    Flashing device status light
    Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
    Nov 20, 2008 | Dell Latitude D600 Notebook
    Flashing green light wont stop tv wont turn on
    blown caps on the mainboard,,,had the same problem cost of repair 400.00
    Aug 17, 2008 | Televison & Video
    Alarm light wont stop flashing
    How old is your printer? Maybe a part in your printer has reached its service life and has to be replaced. Please indicate error messages if there are any.
    Mar 31, 2008 | Canon i860 InkJet Photo Printer
    Mitsubishi WD-62525 62" Rear Projection HDTV Logo
    557 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
