Question about Star Cibox Inter@ctive C1905 19 inch LCD Monitor
I am trying to find drivers and a user manual for my cibox tft 1905 flat screen lcd monitor
SOURCE: Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
first of tell me is it a TFT or LCD. the LCD life is not more then 5 years. if it is tft then check the back panel of ur TFT, the high voltage flyback capacitor or boost capictor is loosing power.
Posted on Feb 07, 2008
bammbammfran
  • 159 Answers
SOURCE: Emachine 19" Widescreen Flat-Panel TFT-LCD Monitor
Your power/inverter board is in need of an overhaul.
The capacitors are failing and possibly a transistor.
If the screen showed any redness or pink whebn it was working, Then there is a slight chance that one or more of the 4 lightbulbs in the screen was going bad and finally went.
If you take it apart and send me a picture, I may be able to tell by looking at it.
I repair these boards on ebay
bammbammfran
Posted on Nov 06, 2008
leroyal
  • 2120 Answers
SOURCE: Monitor Driver
You don't need one unless you have built in speakers.
Posted on Feb 14, 2009
  • 135 Answers
SOURCE: Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Posted on Feb 24, 2009
net2mani
  • 129 Answers
SOURCE: I used my computer earlier
your moniter/lcd is ok you need following steps to solve your problem
1.there should be frequency problem.lcds are not compatible with 75hz or greater. you have to change it from resolution advance setting (using your friends moniter or your another moniter) set it to 60hz then check your problematic lcd.moniter is recomended for this testing because it capable of 75 to120hz.
2.if first step not solve your problem then check rams , cable and vgais proper connected with motherboard.(pc is keep stuck if some thing rong with ram, hhd, cd-rom and pci cards).
hope your problem is solved with these steps.
Posted on May 12, 2011
I have an LCD monitor, model 1703FPt. the power led on the lower panel of the monitor turns on BUT the screen remains Black Blank. nothing comes on the screen. need help.
Check the data connector on the Monitor. Not the power cable but the other one. Try changing that and see if it solves the problem.
I hope you have the correct drivers installed for your monitor based on the OS of your computer.
Jul 28, 2010 | Dell 1703FPt 17" TFT LCD Flat Panel...
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
E171Fpb driver on dimension 2400
installing windows again then the monitor driver should resolve the problem
Jun 25, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Star Cibox Inter@ctive C1905  19 inch LCD Monitor Logo
183 people viewed this question
Top Star Computers & Internet Experts
Abdul Mannan
Abdul Mannan
Marvin
Marvin
Are you a Star Computer and Internet Expert? Answer questions, earn points and help others
