Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
My Makita dcs 4610 chansaw is not putting oil on the chain. The oil resevoir is full but no oil. I have cleaned it in general but want to know where the oil comes out in case it is blocked.
    Brigadier General:
  • 4,088 Answers
Remove the bar and chain, then clean the side of the engine case where the bar fits to. Start the engine--oil should ooze out of a small port in the engine case. If ok, clean the bar and cover, then clean the two small oil channels in the drive end of the bar which allow oil to flow out into the chain groove on each side (only one is active depending on which side of the bar is 'down'). If no oil came out of the engine port, then you need to investigate the oil pump (behind the clutch), oil lines, and oil filter in the tank. The oil pump, in particular, has plastic gears that can become damaged. When oil appears at the port, assemble the bar and chain. Adjust the chain (cover fastemers finger tight) so that the chain just pulls up to the lower bar edge, but not so tight that the chain can't be pulled by hand. Make sure the teeth cut toward you on the bottom run and are properly sharpened. Tighten the cover fasteners firmly and recheck tension. If ok, run the saw at speed for several moments with the tip near some cardboard--it should throw off a thin line of oil. Hope this helps!
Posted on Jul 10, 2010
Makati DCS 4610 chain saw is not getting oil through to te chain but the tank is full
How old is the saw? The first and easiest thing to do will be to drain the oil tank and make sure that filter isn't plugged. It's probably wise to fill the tank half way with fuel mix while it's empty and give it a few good swishes to clean it out real good. Next make sure that oil holes on your bar aren't clogged with gunk. After that take off the clutch cover, and remove the bar and chain. Start the saw and see if your getting any oil to the discharge. If you have oil there, make sure that the oil hole on the bar lines up with the oil discharge on the saw. If you're not getting oil at the discharge, your oil pump is likely faulty.
Mar 17, 2017 | Garden
Trouble starting chain saw
check for spark and install new spark plug take off air filter check for fuel
Feb 12, 2015 | Makita DCS6421 64cc Chainsaw with 20" Bar...
How to separate the crankcase on a Makita dcs 540 chainsaw?
You can see how to repair this saw in the Makita DCS540 Manual. It is around page 28 I think.
Feb 05, 2013 | Makita Dcs 540, 20" Chainsaw Chain 78dl...
Brand new, seems like everything assembled fine. Won't start. Right gas mix, right chain saw oil. No start. Makita dcs 400.
remove the chain and bar and try to start without it, if it start then chain was too tight. also you may need to do a small adjustment to carburator. check spark plug gap. check for spark. even brand new one need an adjustment at first use. if you can not make it start it has warranty. take it where you bought it.
Feb 09, 2011 | Garden
Excessive oil from the chain oiler. oil resevoir is empty and fuel is still 3/4 full. Saw is two weeks old. Oil sprays off the bar.
What kind of oil did you put in there?? The bar and chain oil is so thick, i can't see it slinging anywhere, you must have used 2 stroke in there. It's OK, That is all I use in my Husky, but it doesn't sling off. I don't know if you have a part missing or what, but there is a little damper right under the chain guard. Check it out, hope this helps.
Oct 19, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Makita DCS51018 Chain Saw Oiler
OK found a complete oil pump for this saw, part number is 181245250 and if you would like to download a copy of the breakdown go to Makitatools.com and in the bottom go to Makita Canada and you can find it there. I don't know why they don't have it in the US version but that is where I got it from Good Luck and let me know if I can be of any more help
Feb 22, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Makita dcs 34 oil not getting to chain bar
Clarification Request
Posted by rowdy45176 on Feb 21, 2009
What I would do first is remove the bar and run the saw a short time to see if oil coming out of pump (make sure there is oil in the tank) if so recheck the bar for blockage in the small round hole in the side and run something like a paper clip or small piece of metal to clean out the groove. If you need a breakdown for this tool you might want to try Makitatools.com. I haven't checked to see if it is there but usually it would be. Good luck
We need Make, model and serial numbers from the manufacturer's tag to help you any more. Your manuals can be found here:
Dolmar/Makita
http://www.makita.ca/index2.php?event=toollist&categoryid=7
GL
Lou
Feb 21, 2009 | Makita Garden
Can't get clutch plate off of makita 340 dcs
you need a piston stop to stop the engine from rotating,then with a clutch tool you can spin off the clutch,most of them are left had thread.if you don't have a clutch tool you can use a hammer and punch on one of the main arms of the clutch itself.for a piston stop you can use a piece of 1/4"rope.put the piston at the bottom of the stroke and stuff the rope in the sparkplug hole,this stops the piston from reaching it's full stroke.
Oct 20, 2008 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
616 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
