Question about Kenmore Elite 45986 Front Load Washer
Kenmore front load HE3 is leaking from underneath the unit , I checked the gray seal and it seems fine , I did have a large load in . Any ideas
  • 5,911 Answers
If your Kenmore FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Jul 10, 2010
What is the most common reason for my washer to leak water
leaks are usualy from the drain or fill pipes, or door seal(front loaders), and lastly, the pump.
I recommend starting at the hoses, then check seal, then pump
Nov 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tub seal relacement method
The following link explains the step-by-step procedures for replacing the door bellow on a Kenmore Elite HE3:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Jul 16, 2009 | Kenmore 44072 Front Load Washer
Replace a leaking seal
sorry to tell you but it's very hard and i would suggest calling an expert. before u do push up on the inside of the tub to check for slack. if you feel looseness or a gap up and down(like the tub is loose at the back) you may have a support bearing going out and may have caused the front boot seal to leak. now we are getting into some serious money so wiegh it carefully. :)
Jun 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I just purchase a Used Kenmore Washing machine HE3 Elite
Check the belt , or the motor, when you turn it on if you see the motor spin then replace the belt or vis versa. You can do this one of two ways. Tilt it up so you can see underneath the unit or remove the back panel
Feb 09, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 seems to use way more than 10.5 gallons
well the water is meter by the unit ,,but i can give you the read outs,,large loads 12 - 14 gallons..medium loads 10 -11 1/2 gallons small loads 9..these are tech estim...it depend on clothing being wash,,,good luck onthejob
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Fine Gray Residue at End of Wash
Probably residue that has built-up. There is now a front-load cleaner that is sold in most all stores; try it and see if that helps out. You use it just like detergent, but it is specifically for the washer insides. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 27, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
474 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
